coq-club - Re: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • Date: Thu, 2 Jun 2016 13:29:22 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f171.google.com
  • Ironport-phdr: 9a23:hOGQHRHqtNO47aQ397yEE51GYnF86YWxBRYc798ds5kLTJ75ocywAkXT6L1XgUPTWs2DsrQf27uQ7vGrADRRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0psyYOl0ZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OShh78ry8BLHUAGn530GU2xQnAAeUCbf6xSvd53xszD6u+k18S+TO8G+Gbk+WTW576poDhbugSELcT847G7/hcl5jaYdqxWk8U8si7XIaZ2YYaItNpjWeskXEDJM
To make your rewrite succeed, you need to show that Equivalence respects pointwise iff between relations, which is essentially what the error message suggests.
I merely proved the missing constraint in the error message (after generalizing nat to A), and your rewrite then succeeds:
Global Instance pr {A} : Proper
        (pointwise_relation A (pointwise_relation A iff) ==> Basics.flip Basics.impl)
        Equivalence.
Proof.
  intros ? ? ? ?.
  unfold pointwise_relation in H.
  constructor; intros ?; intros; rewrite H in *; eauto with relations.
  eapply transitivity; eauto.
Qed.
Lemma eqb_equiv : Equivalence (fun m n => Nat.eqb m n = true).
Proof.
  setoid_rewrite Nat.eqb_eq.
On Thu, Jun 2, 2016 at 1:17 PM, Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Emilio,
thanks for your suggestion! I considered moving to ssreflect several times, maybe I should.
My larger goal is to create order structures (like TotalOrder) from user supplied types and boolean comparison operators in a reasonably efficient way. Using Nat.eqb was just an example. I am interested in elegant proof techniques for such kind of goals, but not so much in this specific goal.
Best regards,
Michael
-----Original Message-----
From: Emilio Jesús Gallego Arias [mailto:e+coq-club AT x80.org]
Sent: Thursday, June 2, 2016 7:04 PM
To: Soegtrop, Michael <michael.soegtrop AT intel.com>
Cc: coq-club AT inria.fr
Dear Michael,
"Soegtrop, Michael" <michael.soegtrop AT intel.com> writes:
> Require Export Relations Morphisms Setoid Equalities.
> Require Import Arith.
> Proof.
I am not sure what you intend to prove, but here's a different proof your result (using ssreflect's == equality instead of Nat.eqb).
From mathcomp
Require Import ssreflect ssrbool ssrnat eqtype ssrfun seq.
Lemma eqb_equiv : Equivalence (fun m n : nat => m == n).
Proof.
constructor.
- exact: eqxx.
- by move=> x y; rewrite eq_sym.
- by move=> x y z /eqP->.
Qed.
Best,
Emilio
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
