coq-club - RE: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Elegant way to show Equivalence (fun m n => Nat.eqb m n = true) from standard library lemmas?
  • Date: Fri, 3 Jun 2016 09:22:51 +0000
  • Accept-language: de-DE, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga09.intel.com
  • Ironport-phdr: 9a23:CQVXqBOOXIF1HS1RGxol6mtUPXoX/o7sNwtQ0KIMzox0KPv6rarrMEGX3/hxlliBBdydsKIVzbSN+Pm6EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Xxibv5osebSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBO/xeL19RrhFBhwnNXo07Yvlr1OLGQCI/z4XVngcuhtOGQnMqh/gCMTfqCz/46BG3ySVIdfxVfR8fDWp765mTFWg3CIGPD4w/WWRkct9g75BpwqJphpjzoqSa4aQYqktNpjBdM8XEDISFv1aUDZMV9ux
Dear Abhishek, Dear Coq Users,
I made some experiments around your suggestion. It goes fairly well, just at one point I got stuck. I have a type class Welldefined:
Class Welldefined {t : Type} (eq : relation t) (ord : relation t) :=
  welldefined :> Proper (eq==>eq==>iff) ord
which I use in my order structures to express that lt and le are well defined with respect to eq. For rewriting under Welldefined, I need two proper instances, one for rewriting each argument:
Global Instance Proper_Welldefined1 {T : Type} (RR : relation (relation T)):
  Proper
    (pointwise_relation T (pointwise_relation T iff) ==> RR ==> Basics.flip Basics.impl)
    Welldefined.
Global Instance Proper_Welldefined2 {T : Type} (R : relation T):
  Proper
    (pointwise_relation T (pointwise_relation T iff) ==> Basics.flip Basics.impl)
    (Welldefined R).
The second one is easy, but the first one I find a bit hard to prove, because I need to show Welldefined R U from Welldefined S V. But I have the pointwise only between R and S. All I have for U and V is RR U V for some relation-relation RR.
The complete error message I get when I do a rewrite of the first argument of Welldefined is:
Error: setoid rewrite failed: Unable to satisfy the following constraints:
UNDEFINED EVARS:
?X195==[ |- relation (relation nat)] (internal placeholder) {?r}
?X196==[(do_subrelation:=do_subrelation)
          |- Proper (pointwise_relation nat (pointwise_relation nat iff) ==> ?X195 ==> Basics.flip Basics.impl)
               Welldefined] (internal placeholder) {?p}
?X197==[ |- ProperProxy ?X195 (fun x x0 : nat => (x <? x0) = true)] (internal placeholder) {?p0}
I would very much appreciate some help with this.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
