- From: Alan Schmitt <alan.schmitt AT polytechnique.org>
- To: James Wilcox <wilcoxjay AT gmail.com>
- Cc: coq-club AT inria.fr, jrw12 AT cs.washington.edu
- Subject: Re: [Coq-Club] Suggestions for Proof General?
- Date: Fri, 17 Jun 2016 14:51:11 +0200
On 2016-06-16 18:30, James Wilcox
writes:
> It's pretty embarrassing to show this dirty hack in public. Surely there is
> a
> better way!
I don't know if this is better, and it clearly is ugly without a nice
CSS and syntax highlighting (both are easy to set up), but I use
org-mode to document and execute Coq developments. Here is an example
input file http://alan.petitepomme.net/tips/test_coq_exec.org and the
resulting output http://alan.petitepomme.net/tips/test_coq_exec.html.
The glue code to do it is at
http://alan.petitepomme.net/tips/executing_coq.html
To document Coq code from outside the development (if you don't want to
have too much prose in your code), you can use this approach
http://alan.petitepomme.net/tips/documenting_coq.html
Best,
Alan
OpenPGP Key ID : 040D0A3B4ED2E5C7
Monthly Athmospheric CO₂, Mauna Loa Obs. 2015-05: 403.94, 2016-05: 407.70
signature.asc
Description: PGP signature
- Re: [Coq-Club] Suggestions for Proof General?, (continued)
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/15/2016
- Re: [Coq-Club] Suggestions for Proof General?, Pierre Courtieu, 06/16/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/16/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/16/2016
- Re: [Coq-Club] Suggestions for Proof General?, Gabriel Scherer, 06/16/2016
- Re: [Coq-Club] Suggestions for Proof General?, James Wilcox, 06/16/2016
- Re: [Coq-Club] Suggestions for Proof General?, Nico, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Alan Schmitt, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jason Gross, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Emilio Jesús Gallego Arias, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Paul A. Steckler, 06/17/2016
