- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Suggestions for Proof General?
- Date: Fri, 17 Jun 2016 13:11:43 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:FDGvqRfY0Sc9mEjG7lu7Ti50lGMj4u6mDksu8pMizoh2WeGdxc6+Yx7h7PlgxGXEQZ/co6odzbGG4uaxASdZuM7JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuCO04R3WL1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDuR7JBgXD8CbCX4u09wD+v/dx1S3SacbyQLU5Xyjk96Z3YBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
On 2016-06-17 12:47, Jonathan Leivent wrote:
> How about a real-time extraction window? This was started, but not
> completed.
> I think the last time I checked there were issues on the Coq side in that
> what
> it was sending was a non-optimized extraction - what the window showed was
> much larger/complex than what would be extracted via the Extraction command
> when the definition was finished.
This is complete on the PG side IIRC (in company-coq, technically). The
remaining aspects are on the Coq side, right?
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Suggestions for Proof General?, (continued)
- Re: [Coq-Club] Suggestions for Proof General?, Alan Schmitt, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jason Gross, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Emilio Jesús Gallego Arias, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Paul A. Steckler, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/17/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/20/2016
- Re: [Coq-Club] Suggestions for Proof General?, John Wiegley, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Jonathan Leivent, 06/18/2016
- Re: [Coq-Club] Suggestions for Proof General?, Clément Pit--Claudel, 06/18/2016
