coq-club - Re: [Coq-Club] Suggestions for Proof General?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Suggestions for Proof General?
  • Date: Sat, 18 Jun 2016 10:52:36 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f181.google.com
  • Ironport-phdr: 9a23:Xr5zlxDmFNDoglTWXiqcUyQJP3N1i/DPJgcQr6AfoPdwSP74rsbcNUDSrc9gkEXOFd2CrakU2qyH6eu/ByQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTmkbHosMKNKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1kbVGwKkhNOSyzI7Q/3WIu55in9sOt+1S2XMOX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
On 06/17/2016 10:26 PM, Clément Pit--Claudel wrote:
On 2016-06-17 19:26, Jonathan Leivent wrote:
Here's a priority order of what I'd like to see without scrolling, if the
goal window is big enough:
1. all of the goals in focus, with their hyps
2. all of the current goal, and as many of the next goals as can fit
completely, but at least all conclusions
3. the whole current goal's conclusion, with as many hyps above it as fit
I think 1 + 3 is the current behaviour (IIRC)
3 is the current behavior when room is limited to <= just the current goal, which is why I put it last. In 1 and 2, if room permits, I'd like to see complete goals with hyps, not just their conclusions.
For example, when doing induction, the first subgoal will usually be the base case, which is rarely where the question of "did I use the right kind of induction over the right hyps?" is answerable. Seeing the hyps of the other subgoals would help. Right now, whenever I do a questionable induction, I manually show the other subgoals (^C^A^S n, one at a time) to check them out.
Another is when about to use a goal selector other than 1: (and soon we'll have a richer set of goal selectors).
Another is when there are evars shared across multiple goals, such that how those goals depend (or not) on the evars impacts which goal I'll try to solve next.
There's probably a bunch of ways to try to get more useful info into the goals window. I mentioned hide/show, with increasing hiding done as space runs out. Maybe another would be multiple goal windows. While proving, I rarely need a full vertical window for the script, but often need more than a full vertical window for the goals - so if I could see other goals in other windows, that would be making better use of screen real estate than now. Usually, I have 2 screens to use - but currently that doesn't help me do anything but spread things out horizontally. Unfortunately, neither of those screens can do a portrait/landscape flip.
-- Jonathan
