coq-club - Re: [Coq-Club] decide equality on more types
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] decide equality on more types
  • Date: Mon, 4 Jul 2016 22:57:48 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f178.google.com
  • Ironport-phdr: 9a23:/oVD5hUfwdMB7US4TaN+LCGMbs/V8LGtZVwlr6E/grcLSJyIuqrYZheEt8tkgFKBZ4jH8fUM07OQ6PG4HzZbqsjQ+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0ocaYPVQArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7axHwaW3kWmxwAJwXE8hz8Qt+lsCz8t+lw3CSXFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
On 07/04/2016 09:26 PM, Jason Gross wrote:
What types are you looking to decide equality on?
I'm actually making some progress towards such a decide equality tactic - and was wondering if I might be re-inventing the wheel. Also, having an idea how to do this is far removed from having a robust solution...
The most important additional types I'm interested in are when difficult dependent-indexed-type cases are replaced by equivalent but not-as-difficult dependent parameterized types with equality fields. A primary example is Fin:
Inductive Fin : nat -> Set :=
| F1 : forall n : nat, Fin (S n)
| FS : forall n : nat, Fin n -> Fin (S n).
Goal forall n (a b : Fin n), {a=b}+{a<>b}.
Fail decide equality.
Abort.
It seems to be very hard to automatically via tactics derive anything useful for types like Fin in this direction without using additional axioms like JMeq_eq. However, consider Finx, which is semantically equivalent to Fin, but index-less:
Inductive Finx(n : nat) : Set :=
| Fx1(i : nat)(e : n = S i)
| FxS(i : nat)(f : Finx i)(e : n = S i).
Goal forall n (a b : Finx n), {a=b}+{a<>b}.
Abort.
I have a prototype tactic which will decide equality for Finx (and hopefully other types like it) without additional axioms. It leverages Coq.Logic.Eqdep_dec to handle the equality ("e") fields in the constructors, provided that they are themselves equalities on decidable types (and hence have UIP via the theorems in Eqdep_dec) - which it will then try to solve recursively, etc. It also handles cases where injection yields sigma-typed equalities, again using theorems from Eqdep_dec, again provided with the necessary sub-decidables, which it will again try to solve recursively. It will also use existing typeclass instances of decidable equality instead of trying to solve them itself.
It should leave behind subgoal equalities it can't solve - so it can be composed with other means. Hopefully, it will always solve what can be solved using the above techniques - unlike decide equality which currently fails in any case where something like Fin or Finx is a sub-equality.
For extra credit, maybe if JMeq is around, it should use that for indexed types. However, I prefer using index-less equivalents to indexed types (Finx instead of Fin) for other reasons, so I don't really need to solve indexed cases for my own purposes.
-- Jonathan
On Mon, Jul 4, 2016 at 3:55 PM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
Does anyone know of a version of the "decide equality" tactic that works
on more types?
-- Jonathan
