- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] decide equality on more types
- Date: Fri, 8 Jul 2016 16:19:55 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f176.google.com
- Ironport-phdr: 9a23:CFqdBR85SvD77f9uRHKM819IXTAuvvDOBiVQ1KB90O8cTK2v8tzYMVDF4r011RmSDN2dsKoP0raP+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwud7yzQdaZ1pjun8mJuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT4r9Zf9HFbvOtk/MpdW437eb45RPpWFmcIKWcwse/ssxDfTQKJrl8RU3sblAYAVwrC6hD5U5P8vwP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
On 07/08/2016 01:31 PM, Jonathan Leivent wrote:
On 07/08/2016 12:14 PM, Jonathan Leivent wrote:
On 07/08/2016 11:56 AM, Matthieu Sozeau wrote:
Hi Jonathan,
Both fin_eqdec and Fin3_eqdec are closed under the global context, as they
are using instances of decidable equality for nat and fin.
This eqdec_proof tactic is not able to handle your Finx example currently
though, it's also work in progress. How did you implement your tactic?
I am close to having a standalone demo version that uses the standard Eqdec_dep. So I will send this to you as soon I have it, which should be quite soon. It is not very big or complex.
Attached...
-- Jonathan
Attached is a cleaner version that uses typeclasses for finding sub eqdecs. It doesn't have that horrid combine_subgoals hack, but is quite a bit slower in Fin3_eqdec as a result of not combining all those subgoals and instead just allowing typeclass search to resolve each independently.
-- Jonathan
(*** A version of decide equality without axioms.*) (*Uses 8.5pl1 and may depend on fixes for things like congruence added afterwards - hence it may not work on an earlier build.*) Require Coq.Logic.Eqdep_dec. Global Set Injection On Proofs. (*Do induction on H, but make sure the induction is helpful - a quick check is that its first subgoal is not the same as the original goal. Note that this cheats a little in that it relies on progress not detecting the change to the shelf. *) Ltac helpful_induction H := unshelve (progress (induction H; [|shelve..])). Ltac default_handle_sub_eqdec := shelve. (*Use typeclasses to search for existing eqdec instances:*) Ltac handle_sub_eqdec := try typeclasses eauto; default_handle_sub_eqdec. (*Do injections, making sure they aren't the useless variety that just repeats the injecting hyp (which would cause an infinite loop) - also handle any sigma-based equalities that are either from some previous injection or from the pose_sigmaT mechanism below.*) Ltac do_injections := repeat match goal with | H : @eq (@sigT _ _) _ _ |- _ => apply Eqdep_dec.inj_pair2_eq_dec in H; [subst|handle_sub_eqdec] | H : @eq (@ex _ _) _ _ |- _ => apply Eqdep_dec.inj_right_pair in H; [subst|handle_sub_eqdec] | H : _ = _ |- _ => let H' := fresh in let tH := type of H in injection H as H'; let tH' := type of H' in (*if the result of the injection is no different, avoid it:*) tryif constr_eq tH tH' then fail else idtac; subst end. (*Given a hyp equality, which we really really want to subst, at least on the conclusion, try a bunch of tactics to make it subst:*) Ltac force_subst H := lazymatch type of H with | ?X = ?Y => first [subst X |subst Y |change X with Y |change Y with X |replace X with Y by congruence |replace Y with X by congruence |rewrite !H |rewrite <- !H |fail 1 "Cannot substitute" X "with" Y ] end. (*Given an eqdec conclusion, walk through the args of the compared term and try to discharge each via a sub eqdec:*) Ltac do_next_eqdec := idtac; (*avoid early eval*) let rec f pair := lazymatch pair with | (?A, ?A) => left; reflexivity | (?A ?X, ?A ?Y) => (*pick off first differnce*) let H := fresh in assert ({X=Y}+{X<>Y}) as [H|H]; [(*sub eqdec*) try (*check if there is an induction hypothesis that can be applied:*) match goal with IH :_ |- _ => apply IH; assumption end |(*H:X=Y case*)tryif force_subst H then do_next_eqdec else idtac |(*H:X<>Y case*)try (right; contradict H; do_injections; congruence)] | (?F _, ?G _) => f (F, G) | _ => try (right; discriminate) end in lazymatch goal with | |- ({?X=?Y}+{_}) => f (X, Y) | _ => fail end. (*Given a term (or type), return its head symbol and arity:*) Ltac head_arity term := let rec f x := lazymatch x with | (?F ?A, ?N) => f (F, S N) | _ => x end in f (term, 0). (*Pose a nested sigT for term as H. This is the basis of the mechanism that allows destruct on term when it is very dependently intertwined with the goal. Why this works: this nested sigT container can wrap a copy of term, but do so such that its type is not "co-dependent" with term - meaning that none of term's type indexes are part of this nested sigT's type. That's important because an equality between two such nested sigTs (both wrapping term), with just one side of the equality unfolded to expose the existTs, will maintain a validly typed equality between the destructing term and its generalized counterpart in the conclusion, even though some of term's type indexes change due to the destruct. *) Ltac pose_sigT term H := let rec f h n := lazymatch n with | 0 => h | S ?m => let a := fresh in constr:(sigT (fun a => ltac:(let h' := constr:(h a) in let r := f h' m in exact r))) end in let type := type of term in let ha := head_arity type in let s := lazymatch ha with (?h, ?n) => f h n end in simple refine (let H := _ : s in _); [repeat eapply existT; exact term|]. (*Kind of like "generalize_eqs X; destruct X", but using a nested sigT equality instead of a JMeq to maintain the equivalence between the destructee and the generalized copy of it in the conclusion:*) Ltac depdestruct H := let s := fresh in pose_sigT H s; generalize (eq_refl s); (*conclusion now is "s=s -> ..."*) unfold s at 1; (*unfold only one side of the above s=s equality to make it's H visible*) generalize H; (*all H's visible in the goal are generalized away from being dependent on H*) destruct H; subst s; (*intro just the 2 generalizations above - the first should come back as H if all dependencies on H were removed via the generalization (to force that, first do "revert dependent H; intro H" prior to calling depdestruct)*) intros ? ?; subst; do_injections. (*start an eqdec proof - trying both the non-dependent and dependent mechanisms:*) Ltac start_eqdec := intros; lazymatch goal with |- ({?a=?b}+{_}) => generalize a, b; let X := fresh in intro X; tryif helpful_induction X then (let Y := fresh in intro Y; first[destruct Y | depdestruct Y]) else fail end. (*Do just one level of eqdep, leaving any sub-eqdeps that aren't found via handle_sub_eqdec:*) Ltac decide_equality := try unshelve (start_eqdec;do_next_eqdec;handle_sub_eqdec). Existing Class sumbool. Hint Mode sumbool + + : typeclass_instances. (*** Examples:*) Require Import Arith. Existing Instance Nat.eq_dec. Inductive Fin : nat -> Set := | F1 : forall n : nat, Fin (S n) | FS : forall n : nat, Fin n -> Fin (S n). Instance Fin_eqdec: forall n (a b : Fin n), {a=b}+{a<>b}. Proof. decide_equality. Qed. Print Assumptions Fin_eqdec. Inductive Fin3 : forall n (f1 f2 : Fin n), Set := | F31 : forall m (f1 f2 : Fin m), (f1 = f2) -> Fin3 (S m) (FS _ f1) (FS _ f2) | F3S : forall m (f1 f2 : Fin m), Fin3 m f1 f2 -> Fin3 (S m) (FS _ f1) (FS _ f2). Instance Fin3_eqdec : forall n f1 f2 (a b : Fin3 n f1 f2), {a=b}+{a<>b}. Proof. decide_equality. Qed. Print Assumptions Fin3_eqdec. Inductive Finx(n : nat) : Set := | Fx1(i : nat)(e : n = S i) | FxS(i : nat)(f : Finx i)(e : n = S i). Hint Extern 5 ({?a = ?b}+{?a <> ?b}) => (*handle UIP solutions of eq_dec*) intros; left; apply Eqdep_dec.UIP_dec : typeclass_instances. Instance Finx_eqdec : forall n (a b : Finx n), {a=b}+{a<>b}. Proof. decide_equality. Qed. Print Assumptions Finx_eqdec.
- [Coq-Club] decide equality on more types, Jonathan Leivent, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jason Gross, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/06/2016
- [Coq-Club] Ltac way to detect symbol definedness (was Re: decide equality on more types), Jonathan Leivent, 07/06/2016
- Re: [Coq-Club] decide equality on more types, Matthieu Sozeau, 07/08/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/08/2016
