[Coq-Club] Ltac way to detect symbol definedness (was Re: decide equality on more types)
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Ltac way to detect symbol definedness (was Re: decide equality on more types)
- Date: Wed, 6 Jul 2016 15:35:18 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f169.google.com
- Ironport-phdr: 9a23:Z9v1HBzq6SOhof7XCy+O+j09IxM/srCxBDY+r6Qd0ekTIJqq85mqBkHD//Il1AaPBtSDragawLON6ejJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbWtXNSMxJ3sjaibwN76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsPU4ssVETK/SfqIiTLUeAi51HXoy4ZjJsh/KUQuG4DM4X2QInxxUS1zH6xf7XZr1vybSue902S3cNsrzG+NnEQ++5rtmHUe7wBwMMCQ0pTna
Actually, the current state of Ltac vs. symbol definedness is weaker than what I wrote below. For instance, while this works:
Goal True.
try let x := uconstr:(JMeq) in idtac.
This does not:
Ltac detect := try let x := uconstr:(JMeq) in idtac.
So, it doesn't seem possible to have a tactic detect any kind of symbol definedness in its dynamic (calling) environment.:-(
I will file an enhancement request in bugzilla....
-- Jonathan
On 07/06/2016 02:01 PM, Jonathan Leivent wrote:
For the "using JMeq" case when not all indexes are decidable - this leads to an interesting general question. Some tactics are able to conditionally use something, like JMeq, only if it was previously Required, and do something else instead if not - but those are probably all using plugins to accomplish this choice. How would this be done in pure Ltac?
AFAICT, the only non-plugin mechanism(s) that could be used for such "do things one way if X is not Required, else another way if X is Required" would be based on typeclasses, canonical structures, or hints - but these all require some amount of declaration to exist already in X to set up the search.
Would it make sense to have a way for Ltac to attempt to determine if some things are Required or not, without relying on particular declarations (instances or hints)? For example, the following does not work:
Goal True.
Fail try let x := uconstr:(JMeq.JMeq) in idtac.
because Coq complains very early that JMeq.JMeq isn't in the current environment - earlier than uconstr formation, evidently. It does work for just an unqualified "JMeq" alone, however:
Goal True.
so it is the lookup of id qualifiers that is happening too soon for uconstr - and it thus is possible to conditionalize on Require Import, just not on Require alone.
Would it make sense if uconstrs were allowed to refer to undefined qualified symbols, with the requirement that their qualifications be defined deferred just as is done for unqualified symbols? Should there be some kind of "moral equivalence" between the use of an unqualified symbol and a qualified one when both are undefined?
Or, would it be better to have another form that does this environment querying?
-- Jonathan
- [Coq-Club] decide equality on more types, Jonathan Leivent, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jason Gross, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/05/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/06/2016
- [Coq-Club] Ltac way to detect symbol definedness (was Re: decide equality on more types), Jonathan Leivent, 07/06/2016
- Re: [Coq-Club] decide equality on more types, Matthieu Sozeau, 07/08/2016
- Re: [Coq-Club] decide equality on more types, Jonathan Leivent, 07/08/2016
