- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Difference between dot and semicolon in a proof
- Date: Sun, 17 Jul 2016 22:43:04 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f172.google.com
- Ironport-phdr: 9a23:b6oN9hE1PLjH/G0m6VuATp1GYnF86YWxBRYc798ds5kLTJ75o8uwAkXT6L1XgUPTWs2DsrQf2rKQ7/CrBzRIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14Lrh6vso9X6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuxJ54K16spYcGeWnJ+VrBYBfWT8hKiU+4NDhnRjFVwqGoHUGAUsMlR8dIQ/D5Q36V5G5lib7qOd7xGHOP8rwTLM5XTmvx6huQR7sziwAMmhqoynslsVsgfcD81qarBtlztuJOIw=
On 07/17/2016 09:45 PM, mukesh tiwari wrote:
Hi Everyone,
Pardon me if this is stupid question, but I am trying to understand the
difference between dot (.) and semicolon (;) in Coq. My understanding is
that we can interchange the dot and semicolon in Coq file.
It is not true that one can substitute dot for semicolon. There are several reasons:
1. In the default setting of Coq, with "tac1; tac2", tac2 will be applied to all and only the subgoals of tac1. In "tac1. tac2", tac2 will be applied to the first goal following the application of tac1, which may either be the first subgoal of tac1, or if tac1 solves its goal the next goal after tac1. This behavior can be changed somewhat using 'Set Default Goal Selector "all"' - but not completely.
2. in "tac1; tac2", if tac1 has multiple possible successes, then tac2 may fail on some but not all of them, allowing the combined tactic to backtrack and make progress even if tac2 fails initially. In "tac1. tac2", if tac2 fails initially then there is no backtracking back to tac1.
I have not tried your example, but I would guess by looking at it that there are places where 1 above applies - such as after "case H0" and possibly after "apply Not_union". I doubt that 2 applies at all.
-- Jonathan
If you add dot
after each tactic then you see the intermediate steps/calculation after
applying the tactic to goal, and if you don't want to see the intermediate
steps then use semicolon to combine multiple tactics.
Currently I am trying to go though the coq-graph [1] code.
Lemma Union_dec :
forall (e1 e2 : U_set) (x : U),
{e1 x} + {~ e1 x} -> {e2 x} + {~ e2 x} -> Union e1 e2 x -> {e1 x} +
{e2 x}.
Proof.
intros; case H.
left; trivial.
intros; case H0; intros.
right; trivial.
absurd (Union e1 e2 x). apply Not_union; trivial.
trivial.
Qed.
If I replace all the semicolons by dots then It is not provable by
following the same tactics.
Lemma Union_dec :
{e2 x}.
Proof.
intros. case H.
left. trivial.
intros. case H0. intros.
right. trivial.
absurd (Union e1 e2 x). apply Not_union. trivial.
trivial.
and goal is
U : Set
e1, e2 : U_set
x : U
H : {e1 x} + {~ e1 x}
H0 : {e2 x} + {~ e2 x}
H1 : Union e1 e2 x
n : ~ e1 x
~ e2 x
subgoal 2 (ID 51) is:
Union e1 e2 x
Regards,
Mukesh Tiwari
[1] https://github.com/coq-contribs/graph-basics/blob/master/Sets.v
- [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Jonathan Leivent, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Benjamin Werner, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/19/2016
