- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Difference between dot and semicolon in a proof
- Date: Mon, 18 Jul 2016 09:45:26 +0200
There is a difference between dot and semicolon when the application of a tactic produces more than one subgoal.
Then, the tactic(s) appearing after the semicolon is applied to all the subgoals. When the tactic
is after a dot, it is only applied to the first goal.
You can make your proof a « oneliner » (ie. get rid of all dots) by using semicolon and the
bracket notation:
tac; [tac1 | tacB | tacC]
applies tac, and then tacA to the first produced subgoal (produced by tac), tacB to the second, etc
Benjamin
Le 18 juil. 2016 à 03:45, mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> a écrit :If I replace all the semicolons by dots then It is not provable by following the same tactics.Hi Everyone,Pardon me if this is stupid question, but I am trying to understand the difference between dot (.) and semicolon (;) in Coq. My understanding is that we can interchange the dot and semicolon in Coq file. If you add dot after each tactic then you see the intermediate steps/calculation after applying the tactic to goal, and if you don't want to see the intermediate steps then use semicolon to combine multiple tactics.
Currently I am trying to go though the coq-graph [1] code.
Lemma Union_dec :
forall (e1 e2 : U_set) (x : U),
{e1 x} + {~ e1 x} -> {e2 x} + {~ e2 x} -> Union e1 e2 x -> {e1 x} + {e2 x}.
Proof.
intros; case H.
left; trivial.
intros; case H0; intros.
right; trivial.
absurd (Union e1 e2 x). apply Not_union; trivial.
trivial.
Qed.
Lemma Union_dec :
Proof.
intros. case H.
left. trivial.
intros. case H0. intros.
right. trivial.
absurd (Union e1 e2 x). apply Not_union. trivial.
trivial.and goal is
U : Set
e1, e2 : U_set
x : U
H : {e1 x} + {~ e1 x}
H0 : {e2 x} + {~ e2 x}
H1 : Union e1 e2 x
n : ~ e1 x
~ e2 x
subgoal 2 (ID 51) is:
Union e1 e2 x
Regards,
Mukesh Tiwari
[1] https://github.com/coq-contribs/graph-basics/blob/master/Sets.v
- [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Jonathan Leivent, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, Benjamin Werner, 07/18/2016
- Re: [Coq-Club] Difference between dot and semicolon in a proof, mukesh tiwari, 07/19/2016
