Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
- Date: Wed, 17 Aug 2016 14:08:44 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f173.google.com
- Ironport-phdr: 9a23:U65AqhEAfOSyP+XgVFngQ51GYnF86YWxBRYc798ds5kLTJ75oM+wAkXT6L1XgUPTWs2DsrQf2rOQ6fmrADVYqdbZ6TZZIcQKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9JIfegoyN2vyo/NWLOkMT1WP7O+o5dUzu5UWJ749N0NMkcv5wgjLy4VJwM9xMwm1pIV/B1z3d3eyXuKBZziJLpvg6/NRBW6ipN44xTLhfESh0ezttvJ6jgzCYElDKvidUEjhO00kAPw+Q5xbjG5z1ryHSt+xn2SDcM9elY6ozXGGA6KFiVB/hjm8jOj8n/WfLwphyi6Raox+lqhFXzIvdYYXTP/17KPCONegGTHZMC54CHxdKBZmxOtZXAg==
On 08/17/2016 01:56 PM, Jason Gross wrote:
Note that [refine] is doing a lot of inference for you here. The resulting
proof term is:
match
H1 as H2 in (_ = c)
return
(match c as x return (Eq = x -> Type) with
| Eq => fun h : Eq = Eq => feq eq_refl = feq h
| Lt => fun _ : Eq = Lt => IDProp
| Gt => fun _ : Eq = Gt => IDProp
end H2)
with
| eq_refl => eq_refl
end
The reason that this works is that [comparison] has decidable equality,
and, as shown by UIP_dec, any type with decidable equality satisfies
uniqueness of identity proofs (i.e., proof irrelevance for [eq]). This
return clause is basically an inlining and simplification of the
composition of the decidable equality of [comparison] with the proof that
decidable equality implies UIP.
Perhaps - but why can't inference of the return clause do the same for other cases that have rather trivial decidable equality? For instance, bool:
Goal forall (b:bool)(H:b=b), H=eq_refl.
intros.
refine (match H with eq_refl => _ end).
The refine doesn't help here. Why not? (Yes I know the proof exists in Eqdep_dec, but that is besides the point). I've experimenting with UIP recently, and find it actually quite surprising that the refine works in Michael's goal, considering how it fails to do so in so many other similar cases.
Also, why aren't there any tactics (inversion, destruct, or their dependent variants) that can be used to solve these goals?
-- Jonathan
On Wed, Aug 17, 2016 at 9:23 AM John Wiegley
<johnw AT newartisans.com>
wrote:
SM> I am stuck with a proof that two proofs of equality are equal:"SM" == Soegtrop, Michael
<michael.soegtrop AT intel.com>
writes:
SM> Goal forall (T : Type) (feq : Eq=Eq->T) (H1 : Eq=Eq), feq eq_refl = feq
SM> H1. intros.
SM> As far as I know "@eq_refl comparison Eq" is the only possible proof of
SM> Eq=Eq, so shouldn't all proofs of Eq=Eq be equal to "@eq_refl
comparison
SM> Eq" ? Is there a way to prove this?
Goal forall (T : Type) (feq : Eq=Eq->T) (H1 : Eq=Eq), feq eq_refl = feq H1.
Proof.
intros.
refine (match H1 with
| eq_refl _ => _ |
end).
reflexivity.
Qed.
John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
- [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Soegtrop, Michael, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, John Wiegley, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jason Gross, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jonathan Leivent, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, ikdc, 08/17/2016
- RE: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Soegtrop, Michael, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jean-Marie Madiot, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Hugo Herbelin, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jason Gross, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jonathan Leivent, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Maxime Dénès, 08/18/2016
