RE: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
- Date: Wed, 17 Aug 2016 19:03:50 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga09.intel.com
- Ironport-phdr: 9a23:6Xwj0RE5WpOL1W3xiR2dU51GYnF86YWxBRYc798ds5kLTJ75rs2wAkXT6L1XgUPTWs2DsrQf2rOQ6fmrADZZqdbZ6TZZIcQKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9JIfegoyN2vyo/NWLOkMT1WP7O+o5dU/v5UWJ749N0NMkcv5wgjLy4VJwM9xMwm1pIV/B1z3d3eyXuKBZziJLpvg6/NRBW6ipN44xTLhfESh0ezttvJ6j5lH/Sl7F7XwFF24SjxBgAg7f7Ri8UI27+n/xsfM40y2HN+X3S6o1UHKs9fE4ZgXvjXJNDDk0/33NjdQ0xIdaqxKoqhg1i9rRYYqVPfd6OLjacNwGX21ZdsdXSyFFRIi7at1cXKI6Ie9Eotyl9BM1phykCFz0CQ==
Dear Jason, Jonathan,
thanks for the solution and explanation.
I experimented a bit. I think that this works for any literal term of any
type, even if it doesn't have decidable equality. E.g.:
Open Scope list_scope.
Lemma TestNatList: forall (T : Type) (feq : 3::nil=3::nil->T) (H1 :
3::nil=3::nil), feq eq_refl = feq H1.
Proof.
intros.
refine (match H1 with
| eq_refl _ => _
end).
reflexivity.
Qed.
The resulting proof term is lengthy. I guess the decidable equality is
required if the value compared is not a literal, but a parameter.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Soegtrop, Michael, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, John Wiegley, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jason Gross, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jonathan Leivent, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, ikdc, 08/17/2016
- RE: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Soegtrop, Michael, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jean-Marie Madiot, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Hugo Herbelin, 08/17/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jason Gross, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Jonathan Leivent, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Maxime Dénès, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Hugo Herbelin, 08/18/2016
- RE: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Soegtrop, Michael, 08/18/2016
- Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?, Amin Timany, 08/18/2016
