coq-club - Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proof irrelevance for equalities - is there a trick without axioms?
  • Date: Wed, 17 Aug 2016 19:55:36 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
  • Ironport-phdr: 9a23:zbtthRGB2iaU5uwwaF3Ft51GYnF86YWxBRYc798ds5kLTJ75oMqwAkXT6L1XgUPTWs2DsrQf2rOQ6fqrATJIoc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XznO/gqcl329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrJ6jiR6WBwCI/z4XVngcuhtOGQnMqh/gFN+luSzj8+F5xSOyPMvsTLlyVy70vIlxTxq9qi4cMDhx33vQkdc42KBSuxWnqAZ42JWFSI6QPft6OKjaeIVJFiJ6Qs9NWnkZUcuHZIwVAr9ZMA==
It only works if the type has decidable equality.  list nat has decidable equality.   It is also decidable whether or not a list of any type is nil, or not.  If you instead try (feq : Set::nil = Set::nil -> T), you will find that it does not work.  If you try (feq : Set = Set -> T) it will not work.  If you try (feq : list nat = list nat -> T), it will not work.  If you try (feq : S = S -> T) it will not work.  If you try (feq : eq_refl 0 = eq_refl 0 -> T), it may or may not work (this still has decidable equality, but it is more complicated).
On Wed, Aug 17, 2016 at 12:04 PM Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Jason, Jonathan,
thanks for the solution and explanation.
I experimented a bit. I think that this works for any literal term of any type, even if it doesn't have decidable equality. E.g.:
Open Scope list_scope.
Lemma TestNatList: forall (T : Type) (feq : 3::nil=3::nil->T) (H1 : 3::nil=3::nil), feq eq_refl = feq H1.
Proof.
  intros.
  refine (match H1 with
          | eq_refl _ => _
          end).
  reflexivity.
Qed.
The resulting proof term is lengthy. I guess the decidable equality is required if the value compared is not a literal, but a parameter.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
