coq-club - Re: [Coq-Club] Axioms reported by coqchk
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Axioms reported by coqchk
  • Date: Fri, 19 Aug 2016 22:26:56 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
  • Ironport-phdr: 9a23:lT2smBAda8Ar78McoNE3UyQJP3N1i/DPJgcQr6AfoPdwSP7+oMbcNUDSrc9gkEXOFd2CrakV0qyM7Ou+BSRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmDiKu0uZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XXskzIShLK7X8BWE0XlABJCk7L9kLURJD05wn9sONh2CCcden7TK45Xyjqu6VsTh7rhSMKOhY29WjWjop7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
On 08/19/2016 08:06 PM, Jonathan Leivent wrote:
... But, if one has control over the content of the files containing axioms, I would think that making them instances of typeclasses would be a better approach than relying on redefined tactics:
(*module1*)
Class Admitted := admitted : False.
Ltac Admit := elim admitted.
(*module2*)
Axiom admitted_axiom : False.
Instance Admitted_instance : Admitted := admitted_axiom.
Actually, module2 could be eliminated - and each usage would just be required to do this:
Context {admitted_axiom : Admitted}.
If this were established as a standard, it might be possible to deprecate the Axiom declarative form completely.
Considering this, how much of an incompatibility would it be to do the following - everywhere in the standard library where Axiom Name : AType appears, replace it by:
Class AxiomClass := Name : AType.
Then, rebuild the standard library. There will be definitions that fail - those that rely on the axioms. In each case, take the failed definition and wrap it in a Section that includes the relevant Context for the required axioms (or just add the context directly to the definition's arguments).
Then, there are two kinds of modules - those where at least one Context declaration occurs at top level and those where all Context declarations are within Sections. The standard library should only ever contain the latter. Maybe have a coqc option such that coqc will not allow Contexts at top-level unless the option is turned on. Have the .vo files resulting from modules compiled with this option tagged in some way so that it is easy for a tool like coqchk to spot them.
There would not be any new or differently named modules in the standard library, and all symbols they declare would still be present. The impact on existing developments would be that if they rely on axioms, they would need to add the appropriate Contexts. It would even be possible to have a compatibility file that provided all the Contexts that appear in the standard library.
OK - maybe it wouldn't be so hard to fix the standard library and plugins after all...
-- Jonathan
