- To: "Jonathan Leivent" <jonikelee AT gmail.com>
- Cc: <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Axioms reported by coqchk
- Date: Fri, 19 Aug 2016 11:11:11 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tkdtezx AT mail.nu; spf=None smtp.mailfrom=tkdtezx AT mail.nu; spf=None smtp.helo=postmaster AT imta-38.everyone.net
- Ironport-phdr: 9a23:hES9BhMdjIIX+9Y3JOcl6mtUPXoX/o7sNwtQ0KIMzox0Kfz8rarrMEGX3/hxlliBBdydsKMdzbCI+Pm5ByRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmDjKuorcl329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrJ6jiR6WBymI4HIAUmwQ2j5FAhbI6g2wFsPztS37ted51SSyMsj/TLRyUjOnufRRRQfsmRsAYmol823Lh95gpKdSoRbnoQEpkKDOZ4TAftNyc+vgeM4GDUpcTtpYXShMSMvoc4gDE+cTLc5dpoj54V0T+0jtTTKwDf/in2cbzkT92rc3hrws
I agree with Pierre-Marie Pédrot, it's not a tooling problem.
Libraries should make an effort to offer (if that at all makes sense) an
axiom free subset of their features.
Ade
To:
Date: Fri, 19 Aug 2016 12:37:13 -0400
Certainly, we would like to have some convenient method to determine
that no unexpected axiom usage takes place in some part of a development.
Right now, we have Print Assumptions and coqchk. However, neither quite
does the desired job. There are several reasons for this.
For Print Assumptions - this is currently just a per-definition check,
hence it is difficult to use for a large development containing many
definitions. Furthermore, because it is run from the script itself, it
is susceptible to "plugin misbehavior" - the ability of a plugin to
alter the functionality of just about anything in a script, possibly
causing Print Assumptions to misreport.
For coqchk the issue is that it checks module "inclusion", not actual
definition usage. Hence it will report that axioms are "present' when
Print Assumptions (even without plugin misbehavior) does not. But, it
doesn't load plugins, hence is safe from "plugin misbehavior".
Some have suggested that coqchk, while remaining a module inclusion
checker, could be used for the desired check provided that modules are
careful about their inclusions. The maximal care would be to completely
segregate axiom-providing and axiom-consuming modules from others.
There are two problems with this that I see. One is that there are
existing modules in the standard library and plugins that currently
violate this rule. The other is that the rule itself may force module
developers to contort their modularity in difficult ways just to
accommodate this practice and create modularity problems in other areas.
I would rather not base axiom checking merely on inclusions, even if the
standard library and plugins could be "cleaned up" in this regard. I
think the behavior of Print Assumptions is closer to what people
actually want - but it needs to be made both wider in scope (something
like allowing Print Assumptions on an entire module, which would check
all definitions created in that module), and rendered somehow safe from
"plugin misbehavior". Do people agree with this? If so, should this
become part of coqchk, or be a separate tool?
-- Jonathan
_____________________________________________________________
mail now at http://www.mail.nu
- Re: [Coq-Club] Axioms reported by coqchk, (continued)
- Re: [Coq-Club] Axioms reported by coqchk, Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Ralf Jung, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jacques-Henri Jourdan, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ade Umut Huxtable, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jason Gross, 08/20/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/20/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/21/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/21/2016
