- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Axioms reported by coqchk
- Date: Fri, 19 Aug 2016 17:57:31 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f182.google.com
- Ironport-phdr: 9a23:k3N54BT5u5Exps2HkAEcwTC5Ytpsv+yvbD5Q0YIujvd0So/mwa64YRON2/xhgRfzUJnB7Loc0qyN4vmmAzNLucfJ8ChbNscdD1ld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbshsi6n9q/54fUK10RwmHsOPUoc17u/E2R7pBQ2to6bP5pi1PgmThhQ6xu32RmJFaezV7Xx/yb29pdyRlWoO8r7MVaUK/3LOwSRL1cCyk6YShuvJW4/UqLcQza7XwFF24SjxBgAg7f7Ri8UI2inDH9s79f3y+TIc3/S/gQVDW84qF3AEvqjyEGNDM9/Wz/hcl5jaYdqxWk8U8si7XIaZ2YYaItNpjWeskXEDJM
On 08/19/2016 03:44 PM, Ade Umut Huxtable wrote:
Whether the split makes sense for a specific library is up to the maintainer
to decide,
But, when talking about the standard library and standard plugins, it seems like the user base should have considerable say in this regard.
also allocating manpower might stop it from happening (ignorig project forks).
I don't understand what you mean there.
Without the library commiting to the axiomless subset, an update is more
likely to introduce actually used axioms in a user's development.
In the case when a lemma uses an axiom when there is an alternative axiom-less proof (say by using UIP when UIP_dec would suffice), I think such an unnecessary dependency on an axiom is a bug. Furthermore...
It might be unrealistic to expect libraries to perform the split though,
since apparently not even the standard library follows this suggestion...
So: adding the feature "Print Module Assumptons X." to coqchk (or another
tool) would be nice, but without library owner cooperation, users are at risk of
suprise axioming. Also, having such a tool further lowers the motivation on libraries
to actually bother with splitting.
... having the Print Module Assumptions X - or a checked variant that would be something like Assert Module Assumptions X [assump1, assump2 ...], or via a coqchk-like utility - when used by the standard library itself would ease the maintenance of any such segregation of axioms. The Assert mechanism would also provide users with an easy way to view the assumption dependencies.
Still, despite your argument, it seems that the difficulties of dealing with compatibility weigh quite heavily on Coq developers to the point that such module splitting seems unlikely.
However, at least with the standard library, since all of the Coq script source is available and should be understandable to Coq users, the users that really care about segregating axioms can do so by making their own copies of the standard library modules impacted. This is less true of plugins like Program mode and Psatz, where Coq users that depend on those plugins are far less likely to understand their implementation to the point of being able to do the segregation (and subsequent maintenance) themselves.
-- Jonathan
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), (continued)
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Robbert Krebbers, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk), Guillaume Melquiond, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jacques-Henri Jourdan, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ade Umut Huxtable, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/19/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jason Gross, 08/20/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/20/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/21/2016
- Re: [Coq-Club] Axioms reported by coqchk, Jonathan Leivent, 08/21/2016
- RE: [Coq-Club] Axioms reported by coqchk, Soegtrop, Michael, 08/22/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/22/2016
- Re: [Coq-Club] Axioms reported by coqchk, Ralf Jung, 08/20/2016
