Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- Date: Tue, 06 Sep 2016 16:12:33 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f47.google.com
- Ironport-phdr: 9a23:1tZ0eREAywdH+nT30XbWqp1GYnF86YWxBRYc798ds5kLTJ75osiwAkXT6L1XgUPTWs2DsrQf2rOQ7vGrCT1Ioc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XzgMPgifV329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrJ6jiR6WRgyWo3AYT28+kxxSAgGD4gupcI32t37fv/Zh2CiXIIXNSqI5UCnqu6JiVAPhjQ8CPiIl+WSRjdZ/2vEI6Cm9rgByltaHKLqeM+BzK/vQ
Dear Coq Users,
I have a question regarding reduction of proof terms with dependent types, especially reduction of matches with single patterns. A simple example is this:
Require Import Vector.
Program Fixpoint vector_rev {A : Type} {n1 n2 : nat} (v1 : Vector.t A n1) (v2 : Vector.t A n2) : Vector.t A (n2+n1) :=
match v1 in Vector.t _ n1' return Vector.t A (n2 + n1') with
| nil _ => v2
| cons _ e n1' sv => vector_rev sv (cons A e n2 v2)
end.
Definition Example2_01 :=
cons bool false 1 (
cons bool true 0 (
nil bool
Eval compute in vector_rev Example2_01 (nil bool).
This results in:
= match plus_n_Sm 0 1 in (_ = y) return (t bool y) with
| eq_refl =>
match plus_n_Sm 1 0 in (_ = y) return (t bool y) with
| eq_refl =>
match plus_n_O 2 in (_ = y) return (t bool y) with
| eq_refl => cons bool true 1 (cons bool false 0 (nil bool))
end
end
end
: t bool (0 + 2)
I wonder why Coq can’t reduce this to “cons bool true 1 (cons bool false 0 (nil bool))”. All the matches have just one pattern, so it should be obvious which one it is. I guess this is required to show that “t bool (0 + 2)” is the same as “t bool 2” but isn’t there a simpler way which computes?
If a match is just there to transform types, can’t Coq reduce the match if the types would unify without the match?
Would it help if plus_n_Sm would not be opaque?
Which brings me to the question how I can control automation of Program proof obligations?
- [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/06/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Matthieu Sozeau, 09/06/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Jonathan Leivent, 09/06/2016
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/06/2016
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Guillaume Melquiond, 09/07/2016
