coq-club - [Coq-Club] UIP and decidable equality
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] UIP and decidable equality
  • Date: Fri, 09 Sep 2016 09:15:56 +0200
Hello,
I’ve long wanted to understand the magic behind the unicity of identity
proofs for decidable equality
(https://coq.inria.fr/library/Coq.Logic.Eqdep_dec.html), and doing so
made me realize one can use a weaker hypothesis: a function that, given
an identity proof, returns a canonical one of that type.
#+BEGIN_SRC coq
Variable A : Type.
Variable x : A.
Variable nu : forall y, (x=y) -> (x=y).
Axiom nu_canon : forall y e1 e2, nu y e1 = nu y e2.
#+END_SRC
It is easy to show that if equality is decidable, then it has this property
(this is the same proof as the file above).
#+BEGIN_SRC coq
Definition eq_dec := forall x y : A, x = y \/ x <> y.
Definition nudec (H:eq_dec) y (u : x = y) : x = y :=
match (H x y) with
| or_introl eqtt => eqtt
| or_intror neqtt => False_ind (x = y) (neqtt u)
end.
Lemma eqdec_canon : forall H:eq_dec, forall y e1 e2, nudec H y e1 = nudec H y
e2.
intros.
unfold nudec.
destruct (H x y); trivial.
exfalso; auto.
Qed.
#+END_SRC
I’m wondering about the converse: are there types for which equality is not
decidable, but that have canonical equality proofs hence UIP?
For the record, here is how I showed UIP using nu_canon. It’s basically a
rewriting of Coq.Logic.Eqdep_dec. The first step is the crucial one, and it
always holds (there is no hypothesis on type A):
#+BEGIN_SRC coq
Lemma quasi_UIPrefl : forall (y : A) (e : x = y), (eq_trans (eq_sym e) e) =
eq_refl.
intros.
exact (
match e return eq_trans (eq_sym e) e = eq_refl with
| eq_refl => eq_refl
end
Qed.
#+END_SRC
One may use this to rewrite an equality to one that is base on a canonical
one.
#+BEGIN_SRC coq
Lemma inv : forall (y : A) (u : x = y), eq_trans (eq_sym (nu x eq_refl)) (nu
y u) = u.
intros.
rewrite <- u. (* to change u into eq_refl and y to x *)
apply quasi_UIPrefl.
Qed.
#+END_SRC
To conclude, one uses inv to rewrite both equalities, and the fact that nu
returns a canonical equality.
#+BEGIN_SRC coq
Theorem UIP : forall (y : A) (p1 p2 : x = y), p1 = p2.
intros.
rewrite <- (inv _ p1).
rewrite <- (inv _ p2).
rewrite (nu_canon y p1 p2).
reflexivity.
Qed.
#+END_SRC
Best,
Alan
OpenPGP Key ID : 040D0A3B4ED2E5C7
Monthly Athmospheric CO₂, Mauna Loa Obs. 2015-08: 398.93, 2016-08: 402.25
Attachment: signature.asc
Description: PGP signature
