coq-club - Re: [Coq-Club] UIP and decidable equality
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] UIP and decidable equality
  • Date: Fri, 09 Sep 2016 07:57:04 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f176.google.com
  • Ironport-phdr: 9a23:V6MmBRIgBxTGLzucOdmcpTZWNBhigK39O0sv0rFitYgXIv/xwZ3uMQTl6Ol3ixeRBMOAuqsC1bGd6vqwESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG80Pn38JnOaU0cjz2kJLh2MR+erAPLt8BQj5E0eYgrzR6cgHJTfOIe6nlvPknbyxT1/cC284Rk6D8Bk/0k/s9EF679evJrHvRjED06PjVtt4XQvh7ZQF7X6w==
If you assume function extensionality, then the type [nat -> bool] has UIP, but not decidable equality.  I'm not sure if you can find a type like this without function extensionality.
On Fri, Sep 9, 2016, 12:41 AM Alan Schmitt <alan.schmitt AT inria.fr> wrote:
Hello,
I’ve long wanted to understand the magic behind the unicity of identity
proofs for decidable equality
(https://coq.inria.fr/library/Coq.Logic.Eqdep_dec.html), and doing so
made me realize one can use a weaker hypothesis: a function that, given
an identity proof, returns a canonical one of that type.
#+BEGIN_SRC coq
Variable A : Type.
Variable x : A.
Variable nu : forall y, (x=y) -> (x=y).
Axiom nu_canon : forall y e1 e2, nu y e1 = nu y e2.
#+END_SRC
It is easy to show that if equality is decidable, then it has this property
(this is the same proof as the file above).
#+BEGIN_SRC coq
Definition eq_dec := forall x y : A, x = y \/ x <> y.
Definition nudec (H:eq_dec) y (u : x = y) : x = y :=
  match (H x y) with
  | or_introl eqtt => eqtt
  | or_intror neqtt => False_ind (x = y) (neqtt u)
  end.
Lemma eqdec_canon : forall H:eq_dec, forall y e1 e2, nudec H y e1 = nudec H y e2.
  intros.
  unfold nudec.
  destruct (H x y); trivial.
  exfalso; auto.
Qed.
#+END_SRC
I’m wondering about the converse: are there types for which equality is not
decidable, but that have canonical equality proofs hence UIP?
For the record, here is how I showed UIP using nu_canon. It’s basically a
rewriting of Coq.Logic.Eqdep_dec. The first step is the crucial one, and it
always holds (there is no hypothesis on type A):
#+BEGIN_SRC coq
Lemma quasi_UIPrefl : forall (y : A) (e : x = y), (eq_trans (eq_sym e) e) = eq_refl.
  intros.
  exact (
      match e return eq_trans (eq_sym e) e = eq_refl with
      | eq_refl => eq_refl
      end
Qed.
#+END_SRC
One may use this to rewrite an equality to one that is base on a canonical one.
#+BEGIN_SRC coq
Lemma inv : forall (y : A) (u : x = y), eq_trans (eq_sym (nu x eq_refl)) (nu y u) = u.
  intros.
  rewrite <- u. (* to change u into eq_refl and y to x *)
  apply quasi_UIPrefl.
Qed.
#+END_SRC
To conclude, one uses inv to rewrite both equalities, and the fact that nu
returns a canonical equality.
#+BEGIN_SRC coq
Theorem UIP : forall (y : A) (p1 p2 : x = y), p1 = p2.
  intros.
  rewrite <- (inv _ p1).
  rewrite <- (inv _ p2).
  rewrite (nu_canon y p1 p2).
  reflexivity.
Qed.
#+END_SRC
Best,
Alan
OpenPGP Key ID : 040D0A3B4ED2E5C7
Monthly Athmospheric CO₂, Mauna Loa Obs. 2015-08: 398.93, 2016-08: 402.25
