- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Simplification for typeclass instances
- Date: Fri, 9 Sep 2016 10:09:20 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=dschepler AT gmail.com; spf=Pass smtp.mailfrom=dschepler AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f169.google.com
- Ironport-phdr: 9a23:gOFiMxDYnU995pZZG50oUyQJP3N1i/DPJgcQr6AfoPdwSP7ypsbcNUDSrc9gkEXOFd2CrakV0qyI7+u5ADVIoc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XzjPfgrdUz+7V2I8JJH2c06cud54yCKi0MAQ/5Ry2JsKADbtDfHzeD0wqRe9T9Nsekq7c9KXPayVa05SbtFEGZuaDhtt4XD/CPORgqX53YaTn5e0l8RW1CEv1nGWcLatTKyne5g0mHONsrvCLswRD6K7qFxSRauhj1RZBAj92SCpsV2ja9f6CmqpxFnx4POKNWZL/F+c7vZcMkySm9IX8IXXCtEVNDvJ7ATBvYMaL4L57L2oEED+F7nXVGh
When working with typeclasses, I often find myself wanting something
like a class_simpl tactic which would unfold typeclass projections and
instances (except where the instance is an atomic variable, section
hypothesis, axiom/parameter, etc.). So, for example, in this:
Require Import Morphisms.
Class Zero (A:Type) : Type :=
zero : A.
Class Plus (A:Type) : Type :=
plus : A -> A -> A.
Class Equiv (A:Type) : Type :=
equiv : A -> A -> Prop.
Notation "0" := zero.
Infix "+" := plus.
Infix "==" := equiv (at level 70).
Class Plus0L (A:Type) `{Zero A} `{Plus A}
`{Equiv A} : Prop :=
plus_0_l : forall x:A, 0 + x == x.
Instance prod_zero (A B:Type) `{Zero A} `{Zero B} :
Zero (A * B) :=
(0, 0).
Instance prod_plus (A B:Type) `{Plus A} `{Plus B} :
Plus (A * B) :=
fun p1 => let '(a1, b1) := p1 in
fun p2 => let '(a2, b2) := p2 in
(a1 + a2, b1 + b2).
Inductive prod_equiv (A B:Type) `{Equiv A} `{Equiv B} :
Equiv (A * B) :=
| pair_proper_pre : Proper (equiv ==> equiv ==> prod_equiv A B)
(@pair A B).
Existing Instance prod_equiv.
Instance pair_proper (A B:Type) `{Equiv A} `{Equiv B} :
Proper (equiv ==> equiv ==> equiv) (@pair A B) :=
pair_proper_pre A B.
Instance prod_plus0l (A B:Type) `{Plus0L A} `{Plus0L B} :
Plus0L (A * B).
Proof.
intros [a b].
Here, I would love a class_simpl tactic to do the equivalent of:
unfold equiv, plus, prod_plus, zero, prod_zero.
to convert:
0 + (a, b) == (a, b)
to:
prod_equiv (0 + a, 0 + b) (a, b)
(And then the proof would finish with:
constructor; apply plus_0_l.
Qed.
So, is there an existing tactic which would do this, that I'm missing?
Daniel
- [Coq-Club] Simplification for typeclass instances, Daniel Schepler, 09/09/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jonathan Leivent, 09/09/2016
- RE: [Coq-Club] Simplification for typeclass instances, Soegtrop, Michael, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jonathan Leivent, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jason Gross, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Gaetan Gilbert, 09/09/2016
- Re: [Coq-Club] Simplification for typeclass instances, Daniel Schepler, 09/09/2016
