- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Simplification for typeclass instances
- Date: Mon, 12 Sep 2016 16:15:57 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga09.intel.com
- Ironport-phdr: 9a23:3fGMGx88U+VsYv9uRHKM819IXTAuvvDOBiVQ1KB90+wcTK2v8tzYMVDF4r011RmSDNydtaIP2ree8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkImbtjyT8TZiN3y3OSv8bXSZR9JjXyze/k6eB6xtEDastQcqYpkMKc4jBXT9ChmYeNTkClTIl+cgwz7/oP42Z9o8y1dv7hpo8tBWqXzcqB+VrtVAyg8NHgd5cv3uB2FRgyKsChPGl4KmwZFVlCWpCrxWY3853P3
Michael, your tactic fails in the case where there are ambiguous instances. There is a way around this: you can construct a typeclass that takes in a list and another class and is resolved by an instance of that class not in the list. By applying this recursively, you can get the first n instances of any class. You are right. I think there might be a simpler way, though: use eauto to construct something which consists out of the typeclass instance and the equality. Then this can be solved with eauto backtracking. Best regards, Michael Intel Deutschland GmbH |
- [Coq-Club] Simplification for typeclass instances, Daniel Schepler, 09/09/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jonathan Leivent, 09/09/2016
- RE: [Coq-Club] Simplification for typeclass instances, Soegtrop, Michael, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jonathan Leivent, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Jason Gross, 09/12/2016
- Re: [Coq-Club] Simplification for typeclass instances, Gaetan Gilbert, 09/09/2016
- Re: [Coq-Club] Simplification for typeclass instances, Daniel Schepler, 09/09/2016
