coq-club - Re: [Coq-Club] Simplification for typeclass instances
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Simplification for typeclass instances
  • Date: Fri, 9 Sep 2016 14:48:21 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
  • Ironport-phdr: 9a23:1JolsRJK7N5P6fcSmdmcpTZWNBhigK39O0sv0rFitYgXLfnxwZ3uMQTl6Ol3ixeRBMOAuqsC1bad6vqxESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG80Pn38JnOaS1JgiC8aPV8NkaYtwLU4+sRh4J+Kq83gj/Eo2VFffgekWFvI1OQkhLx6++/+Zdi92JbvPd3pJ0IarnzY6ltFe8QNz8hKW1gvMA=
On 09/09/2016 01:46 PM, Jonathan Leivent wrote:
On 09/09/2016 01:09 PM, Daniel Schepler wrote:
When working with typeclasses, I often find myself wanting something
like a class_simpl tactic which would unfold typeclass projections and
instances (except where the instance is an atomic variable, section
hypothesis, axiom/parameter, etc.). So, for example, in this:
Require Import Morphisms.
Class Zero (A:Type) : Type :=
zero : A.
Class Plus (A:Type) : Type :=
plus : A -> A -> A.
Class Equiv (A:Type) : Type :=
equiv : A -> A -> Prop.
Notation "0" := zero.
Infix "+" := plus.
Infix "==" := equiv (at level 70).
Class Plus0L (A:Type) `{Zero A} `{Plus A}
`{Equiv A} : Prop :=
plus_0_l : forall x:A, 0 + x == x.
Instance prod_zero (A B:Type) `{Zero A} `{Zero B} :
Zero (A * B) :=
(0, 0).
Instance prod_plus (A B:Type) `{Plus A} `{Plus B} :
Plus (A * B) :=
fun p1 => let '(a1, b1) := p1 in
fun p2 => let '(a2, b2) := p2 in
(a1 + a2, b1 + b2).
Inductive prod_equiv (A B:Type) `{Equiv A} `{Equiv B} :
Equiv (A * B) :=
| pair_proper_pre : Proper (equiv ==> equiv ==> prod_equiv A B)
(@pair A B).
Existing Instance prod_equiv.
Instance pair_proper (A B:Type) `{Equiv A} `{Equiv B} :
Proper (equiv ==> equiv ==> equiv) (@pair A B) :=
pair_proper_pre A B.
Instance prod_plus0l (A B:Type) `{Plus0L A} `{Plus0L B} :
Plus0L (A * B).
Proof.
intros [a b].
Here, I would love a class_simpl tactic to do the equivalent of:
unfold equiv, plus, prod_plus, zero, prod_zero.
to convert:
0 + (a, b) == (a, b)
to:
prod_equiv (0 + a, 0 + b) (a, b)
(And then the proof would finish with:
constructor; apply plus_0_l.
Qed.
One can use "constructor; apply plus_0_l" to prove this without doing any unfolding. So, I suppose you are just asking for the unfold so that you see the simplification interactively first?
I don't think there is a way tactically to decide if a definition is an instance, let alone a particular kind of instance. Similarly for projections - although in 8.6, there is an is_proj tactic (thanks to Jason), but I think that is only for primitive projections.
On second thought, there may be a way in 8.5 to tactically detect if a function is basically a projection - either defined directly, or acts like one. Roughly, the way to do this would be to show that calling that function on an arbitrary instance of its first non-dependent arg type, then destructing that instance produces exactly one subgoal in which the function call reduces to a component of that instance (which would be a single var in that subgoal introduced by the destruct). I think that can be done in 8.5.
However, I still think there's no way to detect instances vs. other definitions.
-- Jonathan
