- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Equality for inductive type containing list
- Date: Fri, 07 Oct 2016 08:25:44 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f54.google.com
- Ironport-phdr: 9a23:k3deUB2lF/LBa+JysmDT+DRfVm0co7zxezQtwd8ZsegWLvad9pjvdHbS+e9qxAeQG96KsbQf16GO6eigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbsy8IIPZjty22uau4NWTJlwQ3HvuKY91eT6xtE36stQcyd9pLb90wR/UqFNJff5XzCVmPwTAsQz745KV9YJ/8yVdproa8NxNWLiyK6ExUaBRCRwjOnwp7citsgPMG1jcrkAAW3kbx0IbSzPO6wv3C9Ko6nP3
Another idea is to use a "default" fold/logical predicate on the inductive,
like Forall for lists, avoiding the new predicate. Why do you think induction
couldn't work with those eliminators though? You might need with (P0:=...)...
to specify the predicates for nested occurrences in your case but that's handled I think.
-- Matthieu
On Fri, Oct 7, 2016 at 1:45 AM Pierre Courtieu <pierre.courtieu AT gmail.com> wrote:
2016-10-07 0:33 GMT+02:00 Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>:
> On 06/10/2016 18:18, Pierre-Marie Pédrot wrote:
>> You're actually right. I'll have a look to check if that is easy to
>> generate the proper induction this way.
> To answer myself: I've reread the strict positivity conditions, and it
> seems it is somehow straightforward to derive systematically an
> induction principle for nested inductive types, even when they feature
> complicated features (all effectively too tricky cases are ruled out by
> positivity).
> The idea is simply to add a new toplevel predicate for each instance of
> a nested call in the constructors, which takes the context of the
> instance as argument, and fiddle a bit with that.
> Nonetheless, I'm wondering about the use of such a principle. Indeed, if
> the final goal is that newcomers don't keep asking about the evergreen
> inline fixpoint trick, then this is useless. Actually, the 'induction'
> tactic cannot cope with such a complicated scheme
Can you give an example please? Is it really more complex that what
mutual can give?
P.
- Re: [Coq-Club] Equality for inductive type containing list, (continued)
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Maxime Dénès, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Abhishek Anand, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Jonathan Leivent, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Matthieu Sozeau, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/07/2016
