- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Equality for inductive type containing list
- Date: Fri, 7 Oct 2016 10:55:12 +0200
On 07/10/2016 01:44, Pierre Courtieu wrote:
> Can you give an example please? Is it really more complex that what
> mutual can give?
It depends. Mutual inductives need to have the same fixed parameters,
which is not the case for nested inductives. This requires a bit of
generalization over the context. Otherwise, this is straightforward, e.g.
Inductive foo := Foo : list foo -> foo.
should produce
Lemma foo_rect : forall (P : foo -> Type) (Q : list foo -> Type)
(f : forall l, Q l -> (P (Foo l)))
(f0 : Q nil)
(f1 : forall x, P x -> forall l, Q l -> Q (cons x l)),
forall x, P x.
If you want to do fancy stuff implying non-uniform parameters and
varying nested parameters, think for instance about the following
made-up inductive:
Inductive foo (A : Type) :=
| Foo : forall X, list (foo (A -> X)) -> foo A.
It should generate something of type:
(P : forall A, foo A -> Type)
(Q : forall A X, list (foo (X -> A)) -> Type)
(f : forall A X l, Q A X l -> P A (Foo A X l))
(f0 : forall A X, Q A X nil)
(f1 : forall A X x l, P (X -> A) x -> Q A X l -> Q A X (cons x l)),
forall A (x : foo A), P A x.
PMP
signature.asc
Description: OpenPGP digital signature
- Re: [Coq-Club] Equality for inductive type containing list, (continued)
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Abhishek Anand, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Jonathan Leivent, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Matthieu Sozeau, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/07/2016
