- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Equality for inductive type containing list
- Date: Fri, 07 Oct 2016 11:43:41 +0200
- Organization: LORIA
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
> Inductive foo := Foo : list foo -> foo.
> should produce
> Lemma foo_rect : forall (P : foo -> Type) (Q : list foo -> Type)
> (f : forall l, Q l -> (P (Foo l))) (f0 : Q nil) (f1 : forall x, P x
> -> forall l, Q l -> Q (cons x l)), forall x, P x.
Such is scheme is similar to the one generated in the case of mutual
inductive types.
While it is true that
"induction t using foo_rect"
won't help a newcomer (or even more experienced Coq users ...)
because it won't be able to guess
(Q := fun l => forall x, occ x l -> P x)
orelse (Q := Forall_t P),
it would nonetheless be much better that the ones which are
actually generated by Coq now (which do not traverse the nesting).
Because that foo_rect you display here is powerful enough
to compute with the type of trees, in my opinion. Maybe with
the addition of a fixpoint equation in case you want to compute
with that principle.
DLW
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2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=fZ/I
-----END PGP SIGNATURE-----
- Re: [Coq-Club] Equality for inductive type containing list, (continued)
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Abhishek Anand, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Jonathan Leivent, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/06/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre-Marie Pédrot, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Pierre Courtieu, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Matthieu Sozeau, 10/07/2016
- Re: [Coq-Club] Equality for inductive type containing list, Dominique Larchey-Wendling, 10/07/2016
