coq-club - Re: [Coq-Club] Reduction rule for fixpoints
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Reduction rule for fixpoints
  • Date: Mon, 14 Nov 2016 13:46:25 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 2.mo68.mail-out.ovh.net
  • Ironport-phdr: 9a23:7C5aXB3CphnYwjnlsmDT+DRfVm0co7zxezQtwd8ZsesRKvad9pjvdHbS+e9qxAeQG96KsLQd06GK7+igATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFD0v9kXhIYqBic3SgCB9n5BeuB+wGp4JFeekxv669z28oQ1oHcYgO4o68MVCfayRK8/V7ENVDk=
Hi Randy,
If I read correctly, this restriction is needed even without axioms as
soon as you have strong reduction (i.e. under lambdas, match):
Fixpoint my_identity (n : nat) :=
match n with
| O => O
| S p => S (my_identity p)
end.
Consider the normal form of my_identity. You don't want to infinitely
expand the recursive call.
Maxime.
On 11/14/16 13:35, Randy Pollack wrote:
> Page 134 of the reference manual (8.5pl2) describes the reduction rule
> for a fixpoint application:
> The reduction for fixpoints is:
> when aki starts with a constructor. This last restriction is needed in
> order to keep strong normalization.
> Is is known if this last restriction is needed when the context in
> which the fixpoint application is well typed doesn't contain any
> axioms? (References or examples?)
> What about for specific axioms, such as functional extensionality, axiom K,
> Thanks,
> --Randy
