- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Mysterious type of sig for predicates on identity types
- Date: Wed, 16 Nov 2016 12:41:10 +0100
- Organization: LORIA
Hi all,
I did find out that { H : a = B | ... } has type Prop
under 8.5pl2 ? Why is this so ? This implies that
such a result allows to prove something like
Theorem strange X (P : forall x y, x = y -> Prop) (x y : X) :
(exists H : x = y, P x y H) -> { H : x = y | P _ _ H }.
Proof.
intros (H & ?); exists H; auto.
Qed.
Does this not break extraction ?
Best regards,
Dominique
Le 14/11/2016 à 13:35, Randy Pollack a écrit :
> Page 134 of the reference manual (8.5pl2) describes the reduction rule
> for a fixpoint application:
> The reduction for fixpoints is:
> when aki starts with a constructor. This last restriction is needed in
> order to keep strong normalization.
> Is is known if this last restriction is needed when the context in
> which the fixpoint application is well typed doesn't contain any
> axioms? (References or examples?)
> What about for specific axioms, such as functional extensionality, axiom K,
> Thanks,
> --Randy
- [Coq-Club] Reduction rule for fixpoints, Randy Pollack, 11/14/2016
- Re: [Coq-Club] Reduction rule for fixpoints, Maxime Dénès, 11/14/2016
- Re: [Coq-Club] Reduction rule for fixpoints, Pierre Courtieu, 11/14/2016
- Re: [Coq-Club] Reduction rule for fixpoints, Randy Pollack, 11/14/2016
- [Coq-Club] Mysterious type of sig for predicates on identity types, Dominique Larchey-Wendling, 11/16/2016
- Re: [Coq-Club] Mysterious type of sig for predicates on identity types, Jason Gross, 11/16/2016
- Re: [Coq-Club] Mysterious type of sig for predicates on identity types, Dominique Larchey-Wendling, 11/16/2016
