coq-club - Re: [Coq-Club] Reduction rule for fixpoints
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Reduction rule for fixpoints
  • Date: Mon, 14 Nov 2016 13:14:33 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rpollack0 AT gmail.com; spf=Pass smtp.mailfrom=rpollack0 AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f46.google.com
  • Ironport-phdr: 9a23:TjHZgxCPH/Wx1ISkjKCKUyQJP3N1i/DPJgcQr6AfoPdwSP77rsbcNUDSrc9gkEXOFd2CrakV0KyP6+u9ASRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUqabtcm81viz9pvPeE0IwWPlOfIhZCmx+C7Wr4w9hZZoYo011xGB9nBPYqFdwX5iDVOVhRf1oMmqqs1N6SNV7sgo8cJRGZ39e6AxRr8QWC4+NGQx7cbo7THMSAKO4j0XVWBAwUkAOBTM8ByvBsS5iSD9rOconXDCZcA=
Sorry, I should have said "call by value" in my question. That is
what I'm most interested in. References?
Thanks,
--Randy
On Mon, Nov 14, 2016 at 1:01 PM, Pierre Courtieu
<pierre.courtieu AT gmail.com>
wrote:
> Like Maxime said the fix-reduction is only the unfolding of the fixpoint
> definition, which leads to infinite unfolding if not constrained.
> I guess people in this list will give examples of some deeper modifications
> of the whole reduction relation (like using the call-by-value strategy?)
> that lead to special good properties on closed terms under axiom-free
> environments.
> P.
> 2016-11-14 13:46 GMT+01:00 Maxime Dénès
> <mail AT maximedenes.fr>:
>> Hi Randy,
>> If I read correctly, this restriction is needed even without axioms as
>> soon as you have strong reduction (i.e. under lambdas, match):
>> Fixpoint my_identity (n : nat) :=
>> match n with
>> | O => O
>> | S p => S (my_identity p)
>> end.
>> Consider the normal form of my_identity. You don't want to infinitely
>> expand the recursive call.
>> Maxime.
>> On 11/14/16 13:35, Randy Pollack wrote:
>> > Page 134 of the reference manual (8.5pl2) describes the reduction rule
>> > for a fixpoint application:
>> > The reduction for fixpoints is:
>> > when aki starts with a constructor. This last restriction is needed in
>> > order to keep strong normalization.
>> > Is is known if this last restriction is needed when the context in
>> > which the fixpoint application is well typed doesn't contain any
>> > axioms? (References or examples?)
>> > What about for specific axioms, such as functional extensionality, axiom
>> > K, ...?
>> > Thanks,
>> > --Randy
