- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proving a simple equality
- Date: Sat, 19 Nov 2016 10:43:09 +0100
On 11/19/2016 03:03 AM, noam neer wrote:
Require Import Reals.
Open Scope R_scope.
Goal forall a b, (a+b)^2 = a^2 + 2*a*b + b^2.
intros.
field.
Qed.
but then I tried the same thing with the real power operator, i.e.
Goal forall a b, a>0 -> b>0 -> Rpower (a+b) 2 = (Rpower a 2) + 2*a*b
+ (Rpower b 2).
By default, field for R only works with power that are natural numbers:
Check pow
pow: R -> nat -> R
your goal instead uses the full power function
Check Rpower.
Rpower_nat : R -> R -> R.
So if you want to orive it with field you have first to convert your full
power to nat power. A theorem exists:
Search Rpower (_ ^ _).
Rpower_pow:
forall (n : nat) (x : R) (_ : Rlt R0 x), eq (Rpower x (INR n)) (pow x n)
INR is the convertion fron N -> R. So in order to be able to rewrite
you are left with converting 2 in the real to an INR 2. As a matter
of fact, these two are convertible: INR 2 computes to 2.
you can see that with
Print INR
INR =
fix INR (n : nat) : R :=
match n with
| O => R0
| S O => R1
| S (S _ as n0) => Rplus (INR n0) R1
end
and the fact that in R 2 is encoded as 1 + 1 in R
(to see that, apply for example the tactic set (one := 1) to your goal).
Unfortunately rewrite is not powerful enough to discover this convertion so you have to help Coq. This gives:
Goal forall a b, a>0 -> b>0 -> Rpower (a+b) 2 = (Rpower a 2) + 2*a*b + (Rpower b 2).
intros.
change 2 with (INR 2).
rewrite !Rpower_pow.
change (INR 2) with 2.
field.
trivial.
trivial.
Search (0 < _ + _).
apply Rplus_lt_0_compat.
trivial.
trivial.
Qed.
Laurent
- [Coq-Club] proving a simple equality, noam neer, 11/19/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/19/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/20/2016
- Re: [Coq-Club] proving a simple equality, Gaetan Gilbert, 11/21/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/21/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/22/2016
- [Coq-Club] Re : Re: proving a simple equality, Laurent Thery, 11/22/2016
- Re: [Coq-Club] proving a simple equality, Guillaume Melquiond, 11/22/2016
