- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re : Re: proving a simple equality
- Date: Tue, 22 Nov 2016 10:51:11 +0100 (CET)
Hi,
personally I use lra (Require Import Psatz) but fourier is fine
--Laurent
----- noam neer
<noamneer AT gmail.com>
a écrit :
> thanx.
> BTW, what is the simplest way to prove simple goals like "0<=2"?
> "fourier" works but I wonder if it is not an overkill.
> On Mon, Nov 21, 2016 at 3:01 PM, Laurent Thery
> <Laurent.Thery AT inria.fr>
> wrote:
> > On 11/20/2016 10:07 PM, noam neer wrote:
> >> thanks.
> >> however I just tried to use the same trick in a different goal and it
> >> didn't work -
> >> Goal Rpower 2 3 = 8.
> >> change 3 with (INR 3).
> >> Error: Not convertible.
> >> why didn't it work here ?
> > Numbers are encoded in R with 0 and 1
> > Compare
> > Check (1 + ((1 + 1) * 5)).
> > with
> > Compute (INR 11).
> > So now INR 11 = 11 is not a conversion anymore, you have to prove the
> > replacement. For example:
> > replace (INR 11) with (11%R) by (simpl; ring).
> > Laurent
> > Laurent
- [Coq-Club] proving a simple equality, noam neer, 11/19/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/19/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/20/2016
- Re: [Coq-Club] proving a simple equality, Gaetan Gilbert, 11/21/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/21/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/22/2016
- [Coq-Club] Re : Re: proving a simple equality, Laurent Thery, 11/22/2016
- Re: [Coq-Club] proving a simple equality, Guillaume Melquiond, 11/22/2016
