- From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proving a simple equality
- Date: Mon, 21 Nov 2016 13:37:22 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:N7fCCxGjKSteNZPtsTP7YZ1GYnF86YWxBRYc798ds5kLTJ76oMWwAkXT6L1XgUPTWs2DsrQf2rGQ6furAjNIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwguu14tjYZxhCrDu7e7J7ahus/ivLscxDroJvNq83gjTIpnFFYfgekWxhKE6amVDz58O68YR/2ylWoLcl5slGF6vgKfdrBYdEBSgrZjhmrPbgsgPOGFOC
3 is (1 + (1 + 1)) but (INR 3) is ((1 + 1) + 1) Gaëtan Gilbert On 20/11/2016 22:07, noam neer wrote:
thanks.
however I just tried to use the same trick in a different
goal and it didn't work -
Goal Rpower 2 3 = 8.
change 3 with (INR 3).
Error: Not convertible.
why didn't it work here ?
On Sat, Nov 19, 2016 at 11:43 AM,
Laurent Thery <Laurent.Thery AT inria.fr>
wrote:
On 11/19/2016 03:03 AM, noam neer wrote: Require Import Reals. Open Scope R_scope. Goal forall a b, (a+b)^2 = a^2 + 2*a*b + b^2. intros. field. Qed. but then I tried the same thing with the real power operator, i.e. Goal forall a b, a>0 -> b>0 -> Rpower (a+b) 2 = (Rpower a 2) + 2*a*b + (Rpower b 2). By default, field for R only works with power that are natural numbers: Check pow pow: R -> nat -> R your goal instead uses the full power function Check Rpower. Rpower_nat : R -> R -> R. So if you want to orive it with field you have first to convert your full power to nat power. A theorem exists: Search Rpower (_ ^ _). Rpower_pow: forall (n : nat) (x : R) (_ : Rlt R0 x), eq (Rpower x (INR n)) (pow x n) INR is the convertion fron N -> R. So in order to be able to rewrite you are left with converting 2 in the real to an INR 2. As a matter of fact, these two are convertible: INR 2 computes to 2. you can see that with Print INR INR = fix INR (n : nat) : R := match n with | O => R0 | S O => R1 | S (S _ as n0) => Rplus (INR n0) R1 end and the fact that in R 2 is encoded as 1 + 1 in R (to see that, apply for example the tactic set (one := 1) to your goal). Unfortunately rewrite is not powerful enough to discover this convertion so you have to help Coq. This gives: Goal forall a b, a>0 -> b>0 -> Rpower (a+b) 2 = (Rpower a 2) + 2*a*b + (Rpower b 2). intros. Search Rpower (_ ^ _). change 2 with (INR 2). rewrite !Rpower_pow. change (INR 2) with 2. field. trivial. trivial. Search (0 < _ + _). apply Rplus_lt_0_compat. trivial. trivial. Qed. -- Laurent |
- [Coq-Club] proving a simple equality, noam neer, 11/19/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/19/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/20/2016
- Re: [Coq-Club] proving a simple equality, Gaetan Gilbert, 11/21/2016
- Re: [Coq-Club] proving a simple equality, Laurent Thery, 11/21/2016
- Re: [Coq-Club] proving a simple equality, noam neer, 11/22/2016
- [Coq-Club] Re : Re: proving a simple equality, Laurent Thery, 11/22/2016
- Re: [Coq-Club] proving a simple equality, Guillaume Melquiond, 11/22/2016
