coq-club - [Coq-Club] Question about the formal definition of the guard condition
  • From: "William J. Bowman" <wjb AT williamjbowman.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Question about the formal definition of the guard condition
  • Date: Thu, 8 Dec 2016 17:54:14 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wjb AT williamjbowman.com; spf=Pass smtp.mailfrom=wjb AT williamjbowman.com; spf=None smtp.helo=postmaster AT mail.williamjbowman.com
  • Ironport-phdr: 9a23:U9t4qRTXq/xhy0B2HL06BN0sutpsv+yvbD5Q0YIujvd0So/mwa67bBSN2/xhgRfzUJnB7Loc0qyN4vumBDFLuc3J8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbUekBDgCe3SbJ0NhS/6wvL5ecMho43YJkwzh/Iq34AWaIe72R3IFuV1V6o+cW61IFi9yBRsvcj/clfVKz8Oa8/SOoLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
I have been studying CIC and am trying to understand the termination checker
for recursive functions,
but am confused about whether certain equalities are syntactic equality or
convertibility.
I have read "Codifying guarded definitions with recursive schemes" by E.
Giménez, and transliterated
the definitions from that work into Figure 1 in the following PDF:
https://williamjbowman.com/downloads/guard-q.pdf
At the top of Figure 1, the judgment "fix f:t.e terminates" holds when, among
other things, t = Π (x : (D e' ...)). t'.
That is, when e defines a function whose first argument inhabits an
inductively defined type.
From my reading of the aforementioned paper, I believe that this = means
syntactic equality.
However, the following line from Chapter 4 of the Coq manual leads me to
believe = should mean
convertible (or perhaps reducible-to):
"Each Ai should be a type (reducible to a term) starting with at least ki
products ∀ y1:B1,… ∀ yki:Bki, A′i and Bki an is unductive [sic] type."
There are several other cases where = is used and I'm not sure if it should
mean syntactic equality or
convertibility---cases I have labeled [Guard-AppRec] and [Guard-CaseSmaller]
in Figure 1.
In [Guard-AppRec], we know an application of the recursive function (f e) is
valid if e = y e' ...,
where y is a syntactically smaller variable guarded by a constructor.
Again I wonder if this should be e ≡ y e' ..., i.e, e is convertible, not
just not merely
syntactically equal to, an application of a syntactically smaller variable
etc.
In [Guard-CaseSmaller], we have similar restrictions on the structure of the
branches for the case
analysis.
In Figure 2, I define the guard condition using convertibility instead of
syntactic equality in places
I believe (hope) should be valid.
Can anyone advise me on the correct definition of the guard condition?
William J. Bowman
Northeastern University
College of Computer and Information Science
Attachment: signature.asc
Description: PGP signature
