- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about the formal definition of the guard condition
- Date: Fri, 9 Dec 2016 09:33:10 +0100
Hello William.
For more recent descriptions of the Coq termination checker, have a look at:
- http://coq.inria.fr/files/adt-2fev10-barras.pdf
- http://hal.archives-ouvertes.fr/hal-00651780
- https://tel.archives-ouvertes.fr/tel-01054723/
To which extent this is an accurate description of what is actually currently implemented, I have no idea.
Best regards,
Frédéric.
Le 12/08/2016 à 11:54 PM, William J. Bowman a écrit :
I have been studying CIC and am trying to understand the termination checker
for recursive functions,
but am confused about whether certain equalities are syntactic equality or
convertibility.
I have read "Codifying guarded definitions with recursive schemes" by E.
Giménez, and transliterated
the definitions from that work into Figure 1 in the following PDF:
https://williamjbowman.com/downloads/guard-q.pdf
At the top of Figure 1, the judgment "fix f:t.e terminates" holds when, among
other things, t = Π (x : (D e' ...)). t'.
That is, when e defines a function whose first argument inhabits an
inductively defined type.
From my reading of the aforementioned paper, I believe that this = means
syntactic equality.
However, the following line from Chapter 4 of the Coq manual leads me to
believe = should mean
convertible (or perhaps reducible-to):
"Each Ai should be a type (reducible to a term) starting with at least ki
products ∀ y1:B1,… ∀ yki:Bki, A′i and Bki an is unductive [sic] type."
There are several other cases where = is used and I'm not sure if it should
mean syntactic equality or
convertibility---cases I have labeled [Guard-AppRec] and [Guard-CaseSmaller]
in Figure 1.
In [Guard-AppRec], we know an application of the recursive function (f e) is
valid if e = y e' ...,
where y is a syntactically smaller variable guarded by a constructor.
Again I wonder if this should be e ≡ y e' ..., i.e, e is convertible, not
just not merely
syntactically equal to, an application of a syntactically smaller variable
etc.
In [Guard-CaseSmaller], we have similar restrictions on the structure of the
branches for the case
analysis.
In Figure 2, I define the guard condition using convertibility instead of
syntactic equality in places
I believe (hope) should be valid.
Can anyone advise me on the correct definition of the guard condition?
- [Coq-Club] Question about the formal definition of the guard condition, William J. Bowman, 12/08/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, Frédéric Blanqui, 12/09/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, William J. Bowman, 12/12/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, roux cody, 12/12/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, Gabriel Scherer, 12/12/2016
