- From: "William J. Bowman" <wjb AT williamjbowman.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about the formal definition of the guard condition
- Date: Mon, 12 Dec 2016 14:36:15 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wjb AT williamjbowman.com; spf=Pass smtp.mailfrom=wjb AT williamjbowman.com; spf=None smtp.helo=postmaster AT mail.williamjbowman.com
- Ironport-phdr: 9a23:GZOA0xcuM7foa8JGwHJmpJWelGMj4u6mDksu8pMizoh2WeGdxc2yZB7h7PlgxGXEQZ/co6odzbGH6Oa+Aydcu97B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fn8JrKJg5MmTCVYLVoLRzwox+CmNMRhN4oFac1zhrApzNqPax8wnxtLFTZ10Lj5M2Y459n9yVZvvAr8NFFWKO8dKM9G+8LRA86Onw4sZW4/SLIShGCsyMR
Frédéric,
Thank you for these references! I'll take a look and see if they resolve my
issue.
Do you (or others) know why the "official reference" in the Coq manual is so
outdated?
William J. Bowman
On Fri, Dec 09, 2016 at 09:33:10AM +0100, Frédéric Blanqui wrote:
> Hello William.
> For more recent descriptions of the Coq termination checker, have a look at:
> - http://coq.inria.fr/files/adt-2fev10-barras.pdf
> - http://hal.archives-ouvertes.fr/hal-00651780
> - https://tel.archives-ouvertes.fr/tel-01054723/
> To which extent this is an accurate description of what is actually
> currently implemented, I have no idea.
> Best regards,
> Frédéric.
> Le 12/08/2016 à 11:54 PM, William J. Bowman a écrit :
> >I have been studying CIC and am trying to understand the termination
> >checker for recursive functions,
> >but am confused about whether certain equalities are syntactic equality or
> >convertibility.
> >I have read "Codifying guarded definitions with recursive schemes" by E.
> >Giménez, and transliterated
> >the definitions from that work into Figure 1 in the following PDF:
> > https://williamjbowman.com/downloads/guard-q.pdf
> >At the top of Figure 1, the judgment "fix f:t.e terminates" holds when,
> >among other things, t = Π (x : (D e' ...)). t'.
> >That is, when e defines a function whose first argument inhabits an
> >inductively defined type.
> > From my reading of the aforementioned paper, I believe that this = means
> > syntactic equality.
> >However, the following line from Chapter 4 of the Coq manual leads me to
> >believe = should mean
> >convertible (or perhaps reducible-to):
> > "Each Ai should be a type (reducible to a term) starting with at least
> > ki products ∀ y1:B1,… ∀ yki:Bki, A′i and Bki an is unductive [sic] type."
> >There are several other cases where = is used and I'm not sure if it
> >should mean syntactic equality or
> >convertibility---cases I have labeled [Guard-AppRec] and
> >[Guard-CaseSmaller] in Figure 1.
> >In [Guard-AppRec], we know an application of the recursive function (f e)
> >is valid if e = y e' ...,
> >where y is a syntactically smaller variable guarded by a constructor.
> >Again I wonder if this should be e ≡ y e' ..., i.e, e is convertible, not
> >just not merely
> >syntactically equal to, an application of a syntactically smaller variable
> >etc.
> >In [Guard-CaseSmaller], we have similar restrictions on the structure of
> >the branches for the case
> >analysis.
> >In Figure 2, I define the guard condition using convertibility instead of
> >syntactic equality in places
> >I believe (hope) should be valid.
> >Can anyone advise me on the correct definition of the guard condition?
signature.asc
Description: PGP signature
- [Coq-Club] Question about the formal definition of the guard condition, William J. Bowman, 12/08/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, Frédéric Blanqui, 12/09/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, William J. Bowman, 12/12/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, roux cody, 12/12/2016
- Re: [Coq-Club] Question about the formal definition of the guard condition, Gabriel Scherer, 12/12/2016
