- From: flaviomoura AT unb.br (Flávio L. C. de Moura)
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Proof general problem with Coq 8.4
- Date: Thu, 12 Jan 2017 20:38:15 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=flaviomoura AT unb.br; spf=None smtp.mailfrom=flaviomoura AT unb.br; spf=None smtp.helo=postmaster AT mxb.unb.br
- Ironport-phdr: 9a23:OrURKR28N6kMklHWsmDT+DRfVm0co7zxezQtwd8ZseseI/ad9pjvdHbS+e9qxAeQG96Kt7Qf0qGP7eigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pebNw5PnX+2Za54BBSwtwTY8McM19hMMKE0nxXNq2VJfOFR2HlhDU+VlVD2/I/w0prq7SVX89Znv+UGGan3N4E/UKZRTWd1e1sp7dHm4EGQBTCE4WERBz0b
Hello Coq users,
I am facing a strange problem with Proof General, and I didn't realize
how to solve it. When I try to process a .v file (with Coq 8.4pl4), I
get the following screen:
Don't know what to do with -Q
Usage: coqtop <options>
Coq options are:
-I dir -as coqdir map physical dir to logical coqdir
-I dir map directory dir to the empty logical path
-include dir (idem)
-R dir -as coqdir recursively map physical dir to logical coqdir
-R dir coqdir (idem)
-top coqdir set the toplevel name to be coqdir instead of Top
-notop set the toplevel name to be the empty logical path
-exclude-dir f exclude subdirectories named f for option -R
-inputstate f read state from file f.coq
-is f (idem)
-nois start with an empty state
-outputstate f write state in file f.coq
-compat X.Y provides compatibility support for Coq version X.Y
-verbose-compat-notations be warned when using compatibility notations
-no-compat-notations get an error when using compatibility notations
-load-ml-object f load ML object file f
-load-ml-source f load ML file f
-load-vernac-source f load Coq file f.v (Load f.)
-l f (idem)
-load-vernac-source-verbose f load Coq file f.v (Load Verbose f.)
-lv f (idem)
-load-vernac-object f load Coq object file f.vo
-require f load Coq object file f.vo and import it (Require f.)
-compile f compile Coq file f.v (implies -batch)
-compile-verbose f verbosely compile Coq file f.v (implies -batch)
-opt run the native-code version of Coq
-byte run the bytecode version of Coq
-where print Coq's standard library location and exit
-config print Coq's configuration information and exit
-v print Coq version and exit
-q skip loading of rcfile
-init-file f set the rcfile to f
-batch batch mode (exits just after arguments parsing)
-boot boot mode (implies -q and -batch)
-emacs tells Coq it is executed under Emacs
-noglob do not dump globalizations
-dump-glob f dump globalizations in file f (to be used by coqdoc)
-with-geoproof (yes|no) to (de)activate special functions for Geoproof
within Coqide (default is yes)
-impredicative-set set sort Set impredicative
-force-load-proofs load opaque proofs in memory initially
-lazy-load-proofs load opaque proofs in memory by necessity (default)
-dont-load-proofs see opaque proofs as axioms instead of loading them
-xml export XML files either to the hierarchy rooted in
the directory $COQ_XML_LIBRARY_ROOT (if set) or to
stdout (if unset)
-quality improve the legibility of the proof terms produced by
some tactics
-h, --help print this list of options
I have opam installed, and if I switch to Coq 8.5 or 8.6, everything
works fine. The first line of the above screen says "Don't know what to
do with -Q" but I don't know how to fix this. Any help is very welcome.
Best regards,
Flávio.
- [Coq-Club] Proof general problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- <Possible follow-up(s)>
- [Coq-Club] Proof General problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Pierre Courtieu, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Clément Pit--Claudel, 01/16/2017
