coq-club - Re: [Coq-Club] Proof General problem with Coq 8.4
  • From: flavio.de.moura AT gmail.com (Flávio L. C. de Moura)
  • To: coq-club <coq-club AT inria.fr>
  • Cc: pierre.courtieu AT gmail.com
  • Subject: Re: [Coq-Club] Proof General problem with Coq 8.4
  • Date: Fri, 13 Jan 2017 13:45:54 -0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=flavio.de.moura AT gmail.com; spf=Pass smtp.mailfrom=flavio.de.moura AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f194.google.com
  • Ironport-phdr: 9a23:tIvPfBLTDKlp/O20StmcpTZWNBhigK39O0sv0rFitYgeKfvxwZ3uMQTl6Ol3ixeRBMOAuq4C0LCd4/GocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbQhFgDWwbal8IRmoognctc0bipZ+J6gszRfEvmFGcPlMy2NyIlKTkRf85sOu85Nm7i9dpfEv+dNeXKvjZ6g3QqBWAzogM2Au+c3krgLDQheV5nsdSWoZjBxFCBXY4R7gX5fxtiz6tvdh2CSfIMb7Q6w4VSik4qx2ThLjlSUJOCMj8GzPisJ+kr9VrhyiqRNxzIHbfI6bOeFifqPEZ94WWXZNU9xTWiFHH4iyb5EPD+0EPetAoYn9o0EBrQW/BQmrHu/g1yFHimXz3a09zuQhCxvJ0RcvH9ILqnvUrdH1OL0OXuCyyanD0DHPYfNS2TD/9ojIcxchquyKU75qbMHc11MjHB7YgVqOtIfrODSV1vkXs2eB6uZtU/+khWAgqwF0uDevx8Esh5HGhoIU1lDE9Th5z50vKdKkT057ZNipG4ZTuSGCL4Z6XN8uTmVytCs5yrAKo4C3cDYWxJg92hLSb/OKf5CV7h/iV+udOzN1iG5/dL6hmxq/81KsxvD/W8SyzV1EtDBKksPWuXAIzxHT6taISv96/kq53DaAzQHT6uVdLUAtlqrXN4ctwrAtmpcXvknPBCD2mELxjK+ZckUr5PKk5PjgYrXjvpOcNol0hR/iMqk2hMCzHeA1PhINUmWb4+iwyqPv8VHjTLlXivA7nbHVsJXAKsQaoq65DRVV0oEm6xunATem1M4XnWcGLFJCYh6IkpbmN0vLIPD/EPe/mU6jnSxkx/DDJLLhA5HNImLfn7fmeLZx81RcxxYrzdBD+5JUDakML+70Wk/ordDXEhs5MxGvzOv8E9V81oYeWXqVDaODMaPSt0WI5uM1LOWWao8VomW1F/9w7Pn3yHQ9hFVVKaKuxN4cbG2yNvVgOUSQJ3T21IQvC2AP6wQ6RfLrjxuOXHhWYGuoVooz4zg6DMStCoKLBq6pCaKA22+fWNV9IChKBxipFmryfsTXCL83dCuOL5o5wXQ/Xr+7Rtp52A==
Hi,
I found a way to fix this problem, but I am not sure about it. I changed
the file coq-system.el that comes with Proof General as follows: The two
occurrences of -Q below were changed to -q and I recompiled Proof
General. Therefore, it seems to be a problem of Proof General. Do you
agree?
(defun coq-option-of-load-path-entry (entry &optional pre-v85)
"Translate a single ENTRY from `coq-load-path' into options.
See `coq-load-path' for the possible forms of ENTRY and to which
options they are translated. Use a non-nil PRE-V85 flag to
request compatibility handling of flags."
(if pre-v85
;; FIXME Which base directory do we expand against? Should the entries
of
;; load-path just always be absolute?
;; NOTE we don't handle 'recnoimport in 8.4, and we don't handle 'nonrec
;; in 8.5.
(pcase entry
((or (and (pred stringp) dir) `(ocamlimport ,dir))
(list "-I" (expand-file-name dir)))
(`(nonrec ,dir ,alias)
(list "-I" (expand-file-name dir) "-as" alias))
((or `(rec ,dir ,alias) `(,dir ,alias))
(list "-R" (expand-file-name dir) alias)))
(pcase entry
((and (pred stringp) dir)
(list "-Q" (expand-file-name dir) ""))
(`(ocamlimport ,dir)
(`(recnoimport ,dir ,alias)
(list "-Q" (expand-file-name dir) alias))
(list "-R" (expand-file-name dir) alias)))))
Best regards,
Flávio.
(Flávio L. C. de Moura) writes:
> Hi Pierre,
> The *Messages* buffer is not very informative, except from the
> fact that coq is launched by the command 'coqtop -emacs -Q' and that
> there is no Coq project file. I couldn't find a tip about where the -Q
> comes from. Here is the output:
> Loading coq...
> Welcome to Coq Proof General!
> Coq abbrevs already exists, default not loaded
> Loading coq...done
> Coq project file not detected.
> Welcome to company-coq! Use M-x company-coq-tutorial to get started. [2
> times]
> Right click (or C-click) to show the refactoring menu.
> The Coq Proof Assistant, version 8.4pl4 (May 2016)
> compiled on May 06 2016 08:27:03 with OCaml 4.01.0
> Starting: coqtop -emacs -Q /Users/flaviomoura/workspace-git/tlc/src
> Process coq exited abnormally with code 1
> , shutting down scripting...
> *coq*, cleaning up and exiting...
> *coq* exited.
> , shutting down scripting...done.
> proof-activate-scripting: coq process exited!
> I hope you can find something useful from this output.
> Thank you again!
> Flávio.
> Pierre Courtieu
> <pierre.courtieu AT gmail.com>
> writes:
>> Hi Flavio,
>> In an empty configuration the command launched by pg is "coqtop
>> -emacs". AFAIK any other option comes from user configuration.
>> Once you have started coq, can you look at buffer *Messages* please?
>> It should contain a line describing the coqtop command (and the
>> options) launched. Given the error message you get you should see a
>> -Q option that must come from somewhere in your configuration.
>> The configuration can be in a _CoqProject file inside you project, or
>> (unlikely) in a .dir-locals.el file, or from file variables at the end
>> of your file.
>> Hope this helps,
>> Pierre
>> 2017-01-13 11:27 GMT+01:00 Flávio L. C. de Moura
>> <flavio.de.moura AT gmail.com>:
>>> Hi Pierre,
>>> Before answering your questions, let me give some information:
>>> I installed Proof General from github as follows:
>>> git clone https://github.com/ProofGeneral/PG ~/.emacs.d/lisp/PG
>>> cd ~/.emacs.d/lisp/PG
>>> make clean; make EMACS=/usr/local/bin/emacs
>>>> Hi,
>>>> Your coqtop is launched with -Q option py proofgeneral, which is not
>>>> compatible with coq-8.4. Please give more information on your
>>>> configuration so that we can help you:
>>>> - Does the directory where you start proofgeneral contain a _CoqProject
>>>> file?
>>> No.
>>>> - Does the file where you start proofgeneral contain some file variable
>>> I don't think so... at least I couldn't find any. If there is some file
>>> variable, it is created automatically during the installation process.
>>>> - Do you have some pg related configuration in your .emacs?
>>> Yes.
>>> (load "~/.emacs.d/lisp/PG/generic/proof-site")
>>> (eval-after-load "proof-script" '(progn
>>> (define-key proof-mode-map [(C-down)]
>>> 'proof-assert-next-command-interactive)
>>> (define-key proof-mode-map [(C-up)]
>>> 'proof-undo-last-successful-command)
>>> (add-hook 'proof-goals-mode-hook
>>> (lambda () (setq proof-eagerly-raise nil)))
>>> (add-hook 'proof-response-mode-hook
>>>> - Do you have a .coqrc?
>>> No
>>>> Best regards,
>>>> Pierre Courtieu
>>> Thank you in advance for your help.
>>> Best regards,
>>> Flávio.
>>>> 2017-01-13 1:19 GMT+01:00 Flávio L. C. de Moura
>>>> > Hello Coq users,
>>>> > I am facing a strange problem with Proof General, and I didn't realize
>>>> > how to solve it. When I try to process a .v file (with Coq 8.4pl4), I
>>>> > get the following screen:
>>>> > Don't know what to do with -Q
>>>> > Usage: coqtop <options>
>>>> > Coq options are:
>>>> > -I dir -as coqdir map physical dir to logical coqdir
>>>> > -I dir map directory dir to the empty logical path
>>>> > -include dir (idem)
>>>> > -R dir -as coqdir recursively map physical dir to logical coqdir
>>>> > -R dir coqdir (idem)
>>>> > -top coqdir set the toplevel name to be coqdir instead of Top
>>>> > -notop set the toplevel name to be the empty logical path
>>>> > -exclude-dir f exclude subdirectories named f for option -R
>>>> > -inputstate f read state from file f.coq
>>>> > -is f (idem)
>>>> > -nois start with an empty state
>>>> > -outputstate f write state in file f.coq
>>>> > -compat X.Y provides compatibility support for Coq version X.Y
>>>> > -verbose-compat-notations be warned when using compatibility notations
>>>> > -no-compat-notations get an error when using compatibility notations
>>>> > -load-ml-object f load ML object file f
>>>> > -load-ml-source f load ML file f
>>>> > -load-vernac-source f load Coq file f.v (Load f.)
>>>> > -l f (idem)
>>>> > -load-vernac-source-verbose f load Coq file f.v (Load Verbose f.)
>>>> > -lv f (idem)
>>>> > -load-vernac-object f load Coq object file f.vo
>>>> > -require f load Coq object file f.vo and import it (Require
>>>> > f.)
>>>> > -compile f compile Coq file f.v (implies -batch)
>>>> > -compile-verbose f verbosely compile Coq file f.v (implies -batch)
>>>> > -opt run the native-code version of Coq
>>>> > -byte run the bytecode version of Coq
>>>> > -where print Coq's standard library location and exit
>>>> > -config print Coq's configuration information and exit
>>>> > -v print Coq version and exit
>>>> > -q skip loading of rcfile
>>>> > -init-file f set the rcfile to f
>>>> > -batch batch mode (exits just after arguments parsing)
>>>> > -boot boot mode (implies -q and -batch)
>>>> > -emacs tells Coq it is executed under Emacs
>>>> > -noglob do not dump globalizations
>>>> > -dump-glob f dump globalizations in file f (to be used by
>>>> > coqdoc)
>>>> > -with-geoproof (yes|no) to (de)activate special functions for Geoproof
>>>> > within Coqide (default is yes)
>>>> > -impredicative-set set sort Set impredicative
>>>> > -force-load-proofs load opaque proofs in memory initially
>>>> > -lazy-load-proofs load opaque proofs in memory by necessity (default)
>>>> > -dont-load-proofs see opaque proofs as axioms instead of loading them
>>>> > -xml export XML files either to the hierarchy rooted in
>>>> > the directory $COQ_XML_LIBRARY_ROOT (if set) or to
>>>> > stdout (if unset)
>>>> > -quality improve the legibility of the proof terms produced
>>>> > by
>>>> > some tactics
>>>> > -h, --help print this list of options
>>>> > I have opam installed, and if I switch to Coq 8.5 or 8.6, everything
>>>> > works fine. The first line of the above screen says "Don't know what to
>>>> > do with -Q" but I don't know how to fix this. Any help is very welcome.
>>>> > Best regards,
>>>> > Flávio.
