- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof General problem with Coq 8.4
- Date: Sun, 15 Jan 2017 20:42:15 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:jWxcshBSWpI8g5V8xLMjUyQJP3N1i/DPJgcQr6AfoPdwSP3zp8bcNUDSrc9gkEXOFd2CrakV16yN7uu7CSRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3OervpbXfg9ghTynYLo0Ig/lgx/Ws5w9hQpnJ6At/SPIvj4NUOBf2G9lIRrHlBLx48q24Nh78jh4tPco9soGWqL/KfdrBYdEBSgrZjhmrPbgsgPOGFOC
Hey Flávio,
This could also be a problem with the version detection (maybe PG is
improperly detecting your copy of Coq as 8.5).
Can you open a PG bug report?
Thanks!
Clément.
On 2017-01-13 11:45, Flávio L. C. de Moura wrote:
> Hi,
> I found a way to fix this problem, but I am not sure about it. I changed
> the file coq-system.el that comes with Proof General as follows: The two
> occurrences of -Q below were changed to -q and I recompiled Proof
> General. Therefore, it seems to be a problem of Proof General. Do you
> agree?
> (defun coq-option-of-load-path-entry (entry &optional pre-v85)
> "Translate a single ENTRY from `coq-load-path' into options.
> See `coq-load-path' for the possible forms of ENTRY and to which
> options they are translated. Use a non-nil PRE-V85 flag to
> request compatibility handling of flags."
> (if pre-v85
> ;; FIXME Which base directory do we expand against? Should the
> entries of
> ;; load-path just always be absolute?
> ;; NOTE we don't handle 'recnoimport in 8.4, and we don't handle
> 'nonrec
> ;; in 8.5.
> (pcase entry
> ((or (and (pred stringp) dir) `(ocamlimport ,dir))
> (list "-I" (expand-file-name dir)))
> (`(nonrec ,dir ,alias)
> (list "-I" (expand-file-name dir) "-as" alias))
> ((or `(rec ,dir ,alias) `(,dir ,alias))
> (list "-R" (expand-file-name dir) alias)))
> (pcase entry
> ((and (pred stringp) dir)
> (list "-Q" (expand-file-name dir) ""))
> (`(ocamlimport ,dir)
> (`(recnoimport ,dir ,alias)
> (list "-Q" (expand-file-name dir) alias))
> (list "-R" (expand-file-name dir) alias)))))
> Best regards,
> Flávio.
> flavio.de.moura AT gmail.com
> (Flávio L. C. de Moura) writes:
>> Hi Pierre,
>> The *Messages* buffer is not very informative, except from the
>> fact that coq is launched by the command 'coqtop -emacs -Q' and that
>> there is no Coq project file. I couldn't find a tip about where the -Q
>> comes from. Here is the output:
>> Loading coq...
>> Welcome to Coq Proof General!
>> Coq abbrevs already exists, default not loaded
>> Loading coq...done
>> Coq project file not detected.
>> Welcome to company-coq! Use M-x company-coq-tutorial to get started. [2
>> times]
>> Right click (or C-click) to show the refactoring menu.
>> The Coq Proof Assistant, version 8.4pl4 (May 2016)
>> compiled on May 06 2016 08:27:03 with OCaml 4.01.0
>> Starting: coqtop -emacs -Q /Users/flaviomoura/workspace-git/tlc/src
>> Process coq exited abnormally with code 1
>> , shutting down scripting...
>> *coq*, cleaning up and exiting...
>> *coq* exited.
>> , shutting down scripting...done.
>> proof-activate-scripting: coq process exited!
>> I hope you can find something useful from this output.
>> Thank you again!
>> Flávio.
>> Pierre Courtieu
>> <pierre.courtieu AT gmail.com>
>> writes:
>>> Hi Flavio,
>>> In an empty configuration the command launched by pg is "coqtop
>>> -emacs". AFAIK any other option comes from user configuration.
>>> Once you have started coq, can you look at buffer *Messages* please?
>>> It should contain a line describing the coqtop command (and the
>>> options) launched. Given the error message you get you should see a
>>> -Q option that must come from somewhere in your configuration.
>>> The configuration can be in a _CoqProject file inside you project, or
>>> (unlikely) in a .dir-locals.el file, or from file variables at the end
>>> of your file.
>>> Hope this helps,
>>> Pierre
>>> 2017-01-13 11:27 GMT+01:00 Flávio L. C. de Moura
>>> <flavio.de.moura AT gmail.com>:
>>>> Hi Pierre,
>>>> Before answering your questions, let me give some information:
>>>> I installed Proof General from github as follows:
>>>> git clone https://github.com/ProofGeneral/PG ~/.emacs.d/lisp/PG
>>>> cd ~/.emacs.d/lisp/PG
>>>> make clean; make EMACS=/usr/local/bin/emacs
>>>>> Hi,
>>>>> Your coqtop is launched with -Q option py proofgeneral, which is not
>>>>> compatible with coq-8.4. Please give more information on your
>>>>> configuration so that we can help you:
>>>>> - Does the directory where you start proofgeneral contain a _CoqProject
>>>>> file?
>>>> No.
>>>>> - Does the file where you start proofgeneral contain some file variable
>>>> I don't think so... at least I couldn't find any. If there is some file
>>>> variable, it is created automatically during the installation process.
>>>>> - Do you have some pg related configuration in your .emacs?
>>>> Yes.
>>>> (load "~/.emacs.d/lisp/PG/generic/proof-site")
>>>> (eval-after-load "proof-script" '(progn
>>>> (define-key proof-mode-map [(C-down)]
>>>> 'proof-assert-next-command-interactive)
>>>> (define-key proof-mode-map [(C-up)]
>>>> 'proof-undo-last-successful-command)
>>>> (add-hook 'proof-goals-mode-hook
>>>> (lambda () (setq proof-eagerly-raise nil)))
>>>> (add-hook 'proof-response-mode-hook
>>>>> - Do you have a .coqrc?
>>>> No
>>>>> Best regards,
>>>>> Pierre Courtieu
>>>> Thank you in advance for your help.
>>>> Best regards,
>>>> Flávio.
>>>>> 2017-01-13 1:19 GMT+01:00 Flávio L. C. de Moura
>>>>>> Hello Coq users,
>>>>>> I am facing a strange problem with Proof General, and I didn't realize
>>>>>> how to solve it. When I try to process a .v file (with Coq 8.4pl4), I
>>>>>> get the following screen:
>>>>>> Don't know what to do with -Q
>>>>>> Usage: coqtop <options>
>>>>>> Coq options are:
>>>>>> -I dir -as coqdir map physical dir to logical coqdir
>>>>>> -I dir map directory dir to the empty logical path
>>>>>> -include dir (idem)
>>>>>> -R dir -as coqdir recursively map physical dir to logical coqdir
>>>>>> -R dir coqdir (idem)
>>>>>> -top coqdir set the toplevel name to be coqdir instead of Top
>>>>>> -notop set the toplevel name to be the empty logical path
>>>>>> -exclude-dir f exclude subdirectories named f for option -R
>>>>>> -inputstate f read state from file f.coq
>>>>>> -is f (idem)
>>>>>> -nois start with an empty state
>>>>>> -outputstate f write state in file f.coq
>>>>>> -compat X.Y provides compatibility support for Coq version X.Y
>>>>>> -verbose-compat-notations be warned when using compatibility notations
>>>>>> -no-compat-notations get an error when using compatibility notations
>>>>>> -load-ml-object f load ML object file f
>>>>>> -load-ml-source f load ML file f
>>>>>> -load-vernac-source f load Coq file f.v (Load f.)
>>>>>> -l f (idem)
>>>>>> -load-vernac-source-verbose f load Coq file f.v (Load Verbose f.)
>>>>>> -lv f (idem)
>>>>>> -load-vernac-object f load Coq object file f.vo
>>>>>> -require f load Coq object file f.vo and import it (Require
>>>>>> f.)
>>>>>> -compile f compile Coq file f.v (implies -batch)
>>>>>> -compile-verbose f verbosely compile Coq file f.v (implies -batch)
>>>>>> -opt run the native-code version of Coq
>>>>>> -byte run the bytecode version of Coq
>>>>>> -where print Coq's standard library location and exit
>>>>>> -config print Coq's configuration information and exit
>>>>>> -v print Coq version and exit
>>>>>> -q skip loading of rcfile
>>>>>> -init-file f set the rcfile to f
>>>>>> -batch batch mode (exits just after arguments parsing)
>>>>>> -boot boot mode (implies -q and -batch)
>>>>>> -emacs tells Coq it is executed under Emacs
>>>>>> -noglob do not dump globalizations
>>>>>> -dump-glob f dump globalizations in file f (to be used by
>>>>>> coqdoc)
>>>>>> -with-geoproof (yes|no) to (de)activate special functions for Geoproof
>>>>>> within Coqide (default is yes)
>>>>>> -impredicative-set set sort Set impredicative
>>>>>> -force-load-proofs load opaque proofs in memory initially
>>>>>> -lazy-load-proofs load opaque proofs in memory by necessity (default)
>>>>>> -dont-load-proofs see opaque proofs as axioms instead of loading them
>>>>>> -xml export XML files either to the hierarchy rooted in
>>>>>> the directory $COQ_XML_LIBRARY_ROOT (if set) or to
>>>>>> stdout (if unset)
>>>>>> -quality improve the legibility of the proof terms produced
>>>>>> by
>>>>>> some tactics
>>>>>> -h, --help print this list of options
>>>>>> I have opam installed, and if I switch to Coq 8.5 or 8.6, everything
>>>>>> works fine. The first line of the above screen says "Don't know what to
>>>>>> do with -Q" but I don't know how to fix this. Any help is very welcome.
>>>>>> Best regards,
>>>>>> Flávio.
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Proof general problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- <Possible follow-up(s)>
- [Coq-Club] Proof General problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Pierre Courtieu, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Flávio L. C. de Moura, 01/13/2017
- Re: [Coq-Club] Proof General problem with Coq 8.4, Clément Pit--Claudel, 01/16/2017
