coq-club - [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • Date: Wed, 18 Jan 2017 15:27:19 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f50.google.com
  • Ironport-phdr: 9a23:UWnwfROHnkny598aLJcl6mtUPXoX/o7sNwtQ0KIMzox0KP74rarrMEGX3/hxlliBBdydsKMYzbGH+P65ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9Msfogs+2z+G//YHIK0UN3WLlIOA6EBLjhgLI/uISnIEqfq02017CpmZCU+VQ32JhY1yJyUXS/MC1qbtq7ylS89Em7M9DGfGnIPpkRuQCXT54YzA+vcazuUOfRFGCtyQXXjpIzhRgDA3M7RW8VZD05Hip/tFh0TWXaJWlBYs/Xi6vuuIyEEfl
Hi,
I have noticed that in Coq, we have the following universe constraint:
Prop < Set
I am wondering what is the reason for that?
Wouldn't
Prop <= Set
suffice in this case?
The code that makes the decision is here:
https://github.com/coq/coq/blob/trunk/kernel/uGraph.ml#L716
I wonder whether it is necessary to do:
enforce_univ_lt Level.prop Level.set empty
as now, or we could simply do
enforce_univ_leq Level.prop Level.set empty
I've created an experimental branch where I did the change:
https://github.com/matej-kosik/coq/commit/2fcbb0ced3bc32210ae9fbf4acc40804841c9200
ran some tests:
https://ci.inria.fr/coq/view/coq-contribs/job/coq-contribs/653/console
https://ci.inria.fr/coq/view/opam/job/opam-install/22/console
and I do not see any breakage but the major question is, would this kind of
change make Coq inconsistent
(enable us to prove False)
or not?
Thank you in advance for any insight on this.
Matej Košík
