- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
- Date: Thu, 19 Jan 2017 11:28:41 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb0-f182.google.com
- Ironport-phdr: 9a23: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
> I guess that you wanted to say "Prop is impredicative" and "Set is predicative".
> after starting the toplevel like this:
> coqtop -noinit
> neither Prop nor Set have any inhabitants
I disagree. Inductive types are part of Coq's logic. Even if you didn't declare any inductive type yet, all the inductive types that you could declare form part of the various universes. Inductive types are not like axioms which, as long as you haven't introduced them, are not part of the logic.>
- [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Abhishek Anand, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/18/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Matej Kosik, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Théo Zimmermann, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Maxime Dénès, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Guillaume Melquiond, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Jacques-Henri Jourdan, 01/19/2017
- Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?, Dominique Larchey-Wendling, 01/19/2017
