coq-club - Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why do we have "Prop < Set" ? Why not just "Prop ≤ Set" ?
  • Date: Thu, 19 Jan 2017 13:42:48 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f43.google.com
  • Ironport-phdr: 9a23:2AQaiB1gLBbd6eLYsmDT+DRfVm0co7zxezQtwd8ZseIVKfad9pjvdHbS+e9qxAeQG96Kt7QY0qGN7+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fdbghMizexe7x/IAi5oQjfucQdnJdvJLs2xhbVuHVDZv5YxXlvJVKdnhb84tm/8Zt++ClOuPwv6tBNX7zic6s3UbJXAjImM3so5MLwrhnMURGP5noHXWoIlBdDHhXI4wv7Xpf1tSv6q/Z91SyHNsD4Ubw4RTKv5LptRRT1iikIKiQ5/XnKhMJugqJVoBGvqRJxzIHbYo6aKPVwc7jBfd4ZX2dNQtpdWiJDD466coABD/ABPeFdr4TloFUBtwe+CheuBOjyzzFIgWT23aw50+88FgzL3A4tEtMBvXvIsNn5KqMfXvu0waTLzjjMc+5a1ivh5IfVbBwsruuDUaxufsfVy0QgCx7Kg1eRpIHqMTOYzesNs22B4OphUeKjkXIoqwZ0ojW2wMonl4rHhpoNx1za6Sl0xJw5KN64RUJhf9KoDZtduzuVOoZ4Ws8uXmVltSggxrAGpJK3ZjYGxIgkyhLFdfCKfIeF7xT+X+iLOzh4nmhqeLenihay70egzur8W9Gx0FlQrypFlsDAtnQD1xDP88SHRPRw80m71TaA0ADT7e5EIUQqmqbBN5EhxbswmoISsUTFACD2hF37gLGKekgg4OSl6OTqbq/4qpOBN4J4kA7zP6o2lsy6G+s4MwwOX2aB+eS70b3u5U30TbdLg/A5jqbVrI7WKMAAqaO4AAJY0Zos5wujADu6zdsUg3YKI0hbdB2Zi4XkOU3BL+36APq+jFmsnixmx//DPrL7A5XNKmLPn6vmfbZ480Jc0hY8zchD55JIDbEMOO78WkjotNDBEhA5NxG0zP38BdVm1oIeXHqPDbWDPKPTt1+I/OMvLPOWaI8bojauY8QisvXplDoynUIXVaivx5oeLn6iTdp8JEDMRHPwj9VJMmARvwl2GLG11gGJCWQCbSjiD6ll7Wk3Ut6vV4qSGYuh3+Ld0g+0G5RXYiZNDVXaQiSgTJmNR/pZMHHaGcRmiDFRDbU=
On 01/19/2017 12:28 PM, Théo Zimmermann wrote:
>> I guess that you wanted to say "Prop is impredicative" and "Set is
>> predicative".
> Yes, this is what I meant, sorry. I regularly confuse the terminology.
>> after starting the toplevel like this:
>> coqtop -noinit
>> neither Prop nor Set have any inhabitants
> I disagree. Inductive types are part of Coq's logic.
Where did you read that?
(documentation? source code?)
> Even if you didn't declare any inductive type yet, all the inductive types
> that you could declare form part of the various universes. Inductive
> types are not like axioms which, as long as you haven't introduced them,
> are not part of the logic.
>> Well, if you claim "Prop < Set", how can you say that "Set" is at the
>> bottom of the type hierarchy?
> I want to retract this. But then it really depends on whether we define the
> hierarchy based on < or on : (having a correspondence between the two would
> ease the reasoning but Bruno explained why we
> don't want that).
> Going back to your initial question, Prop and Set are very specific
> universes but if you have some Type@{i} <= Type@{j} universe constraint,
> the constraint resolution algorithm should be able to solve
> this by making Type@{i} = Type@{j}. In the case of Prop and Set, we clearly
> don't want that but, as I said, there seem to be other mechanisms to
> prevent it anyways.
Provided that you are wrong concerning your claim:
Inductive types are not like axioms which, as long as you haven't
introduced them, are not part of the logic.
you make, I think, a wrong conclusion above.
Matej Košík
