coq-club - [Coq-Club] Installation
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Installation
  • Date: Fri, 10 Feb 2017 16:12:52 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=bordg.anthony AT gmail.com; spf=Pass smtp.mailfrom=bordg.anthony AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot0-f178.google.com
  • Ironport-phdr: 9a23:KD9AjBGWJagbJNnkpqT+Yp1GYnF86YWxBRYc798ds5kLTJ75p8qwAkXT6L1XgUPTWs2DsrQf2raQ4/+rBz1Ioc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbktNmsz+2557HUZgxJgnL9PeIzf12KqlDasdBTio9/IO5lwRzQ53BMZu5+xGVyJFvVkQyqtemq+5s22iJMu/Un5oZqVr/2cOxsR7tCADtgOmYp5MrtpDHMSAKO4j0XVWBAwUkAOBTM8ByvBsS5iSD9rOcohHiX
Hi,
I installed Coq 8.6. The installation went smoothly, however I tried to process a file with CoqIDE (the "Forward one command") to check it works and I got the following error after the command "Require Export Relation_Definitions." :
"Error:
The file /home/anthony/coq-8.6/theories/Relations/Relation_Definitions.vo contains library
Coq.Relations.Relation_Definitions and not library Relation_Definitions"
It seems there is a discrepancy between physical names and logical names.
How can I fix this problem ?
Best regards
PhD. Anthony Bordg
postdoctoral fellow
Mathematical Institute Charles University
https://sites.google.com/site/anthonybordg/
