- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Installation
- Date: Fri, 10 Feb 2017 16:40:13 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f180.google.com
- Ironport-phdr: 9a23:l8fdFxz6uNBSQ7/XCy+O+j09IxM/srCxBDY+r6Qd0eoTIJqq85mqBkHD//Il1AaPBtSHraIbwLqH++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9EN/oAZbfhNib0OW7+pubI1kZxWn1XbQnJxKv6A7Vq8Ne1YBlM+M6zgbDinpOYeVfg21ycwG9hRH5s/uwfZlUwSVVvv878sdGV+2uY6Q1SvpKDTEjMkg64cTqsV/ISg7ZtShUaXkfjhcdW1uN1xr9RJqk7nr3
Hi,
When you say "I installed", you mean "I build from source", right? What configuration options did you use? ./configure -local?Le ven. 10 févr. 2017 à 16:13, Anthony Bordg <bordg.anthony AT gmail.com> a écrit :
Best regardsHi,How can I fix this problem ?
I installed Coq 8.6. The installation went smoothly, however I tried to process a file with CoqIDE (the "Forward one command") to check it works and I got the following error after the command "Require Export Relation_Definitions." :
"Error:
The file /home/anthony/coq-8.6/theories/Relations/Relation_Definitions.vo contains library
Coq.Relations.Relation_Definitions and not library Relation_Definitions"
It seems there is a discrepancy between physical names and logical names.
--PhD. Anthony Bordgpostdoctoral fellowMathematical Institute Charles University
https://sites.google.com/site/anthonybordg/
- [Coq-Club] Installation, Anthony Bordg, 02/10/2017
- Re: [Coq-Club] Installation, Théo Zimmermann, 02/10/2017
- Re: [Coq-Club] Installation, Anthony Bordg, 02/10/2017
- Re: [Coq-Club] Installation, Christian Doczkal, 02/10/2017
- RE: [Coq-Club] Installation, Soegtrop, Michael, 02/10/2017
