- From: Christian Doczkal <christian.doczkal AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Installation
- Date: Fri, 10 Feb 2017 18:21:53 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=christian.doczkal AT ens-lyon.fr; spf=Pass smtp.mailfrom=christian.doczkal AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:RuWECBzzm/raXYvXCy+O+j09IxM/srCxBDY+r6Qd0eoTIJqq85mqBkHD//Il1AaPBtSHraIbwLuJ++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9EN/oAZbfhNib0OW7+pubI1kZxWn1XbQnJxKv6A7Vq8M+gI14K693xAGajGFPfrF9xXlpPk6SlhC0ysC77p1q92wEsPI79tVcUKz8Oag/Rq5bBTAOPmYuocn6sh+FQxHZtShUaXkfjhcdW1uN1xr9RJqk7nr3
Hi,
if I want to browse library files, I just dump a corresponding
_CoqProject file into the toplevel directory of the library. In the case
of the Standard Library this file would just contain "-R . Coq" and be
located in the "theories" folder. ProofGeneral picks this up to set the
paths corretly, CoqIDE should do so as well.
Best,
Christian
On 10/02/17 18:08, Anthony Bordg wrote:
> Hi Théo,
> 2017-02-10 17:40 GMT+01:00 Théo Zimmermann
> <theo.zimmi AT gmail.com
> <mailto:theo.zimmi AT gmail.com>>:
> When you say "I installed", you mean "I build from source", right?
> yes, build from the source
> What configuration options did you use? ./configure -local?
> I used "./configure -local", with no further option.
> When you say "I tried to process a file", you mean a file from the
> theories/ folder right?
> yes, a file from the "theories" folder (using CoqIDE)
> If the answer to all these questions is yes, then I've been
> observing the same problem when trying to improve some theories
> files (with Emacs/Proof-General too). I wanted to ask around what
> this was about but did not get to do it yet. However, not being an
> expert on these matters, I'm afraid I can't help further.
> PhD. Anthony Bordg
> postdoctoral fellow
> Mathematical Institute Charles University
> https://sites.google.com/site/anthonybordg/
- [Coq-Club] Installation, Anthony Bordg, 02/10/2017
- Re: [Coq-Club] Installation, Théo Zimmermann, 02/10/2017
- Re: [Coq-Club] Installation, Anthony Bordg, 02/10/2017
- Re: [Coq-Club] Installation, Christian Doczkal, 02/10/2017
- RE: [Coq-Club] Installation, Soegtrop, Michael, 02/10/2017
