coq-club - Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • Date: Sun, 5 Mar 2017 11:59:10 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:shU1HB1NJ1anPwiHsmDT+DRfVm0co7zxezQtwd8ZsesRI/ad9pjvdHbS+e9qxAeQG96KtrQf26GM6+igATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFD+v8QKiI0qBac1wBbTvjMcdO1b2WpuY12Smxzx/NuY8Zh4tiBBvPRn+dQWAvayRLgxUbENVGduCGsy/sC+7RQ=
I expected something like
>Definition IN_IND : same as your type.
>intros;dependent inversion pr.
to do it but apparently it can't.
I put one way to do it in the attached file. The intuition is that if we want to prove something from the structure of (pr : IN foo bar) it's easier if bar is a variable, so make an auxiliary lemma where it is a variable and which proves the same thing on the value we're interested in.
Gaëtan Gilbert
On 04/03/2017 23:08, Lars Rasmusson wrote:
The Agda proof [1] by G. Allais of the Pigeonhole does not use decidability
or excluded
middle. It defines a membership predicate and an induction lemma.
data _∈_ {X : Set} (x : X) : (xs : List X) → Set where
here! : {xs : List X} → x ∈ x ∷ xs
there : {xs : List X} {y : X} (pr : x ∈ xs) → x ∈ y ∷ xs
x∈y∷ys : {X : Set} {x y : X} {ys : List X} {P : (x : X) (pr : x ∈ y ∷ ys) →
Set}
(phere! : P y here!) (pthere : (x : X) (pr : x ∈ ys) → P x (there
pr))
(pr : x ∈ y ∷ ys) → P x pr
x∈y∷ys phere! pthere here! = phere!
x∈y∷ys phere! pthere (there pr) = pthere _ pr
On the last two lines, the proof of the induction lemma considers the two
cases
where pr was constructed using either the 'here!' constructor or the 'there'
constructor.
How would one do that in Coq? Inversion doesn't help here [2]...
Variable (X : Type).
Implicit Type (x : X).
Inductive IN x : list X -> Prop :=
| here xs : IN x (x :: xs)
| there xs y : IN x xs -> IN x (y :: xs).
Arguments here {_ _}.
Arguments there {_ _ _}.
Lemma IN_fwd: forall {x y xs}, IN x (y::xs) -> (x=y \/ IN x xs).
now inversion 1; tauto.
Qed.
Definition IN_IND:
forall {x y ys}
{P : forall x, IN x (y::ys) -> Prop}
(Phere : P y here)
(Pthere : forall x (pr: IN x ys), P x (there pr))
(pr : IN x (y::ys)), P x pr.
Proof.
intros.
destruct (IN_fwd pr).
subst.
(* in the x=y case we have
Phere : P y here
pr : IN y (y :: ys)
P y pr
inversion pr.
(* still no information that pr was created by 'here!' or 'there' *)
How would one write the Agda proof in Coq? How can one compare proof
objects (functions) based on which constructor they were built from (without
EM,functional extensionality, JM_eq or other additional axioms)?
Thanks!
/Lars
[1] https://github.com/gallais/potpourri/blob/master/agda/poc/PigeonHole.agda
[2] https://x80.org/collacoq/agikoxayom.coq
Require Import List. (* for x :: xs notation *)
Definition in_full_destruct:
  forall {x xs}
         {P : forall x, IN x xs -> Prop}
         (Phere : match xs return (forall x, IN x xs -> Prop) -> Prop with
                  | x::xs => fun P => P x here
                  | nil => fun _ => False end P)
         (Pthere : match xs return (forall x, IN x xs -> Prop) -> Prop with
                   | x::xs => fun P => forall y (pr : IN y xs), P y (there pr)
         (pr : IN x xs), P x pr.
Proof.
  intros.
  destruct pr;auto.
Qed.
Definition in_cons_destruct:
  forall {x y ys}
         (Phere : P y here)
Proof.
  intros x y ys P Phere Pthere.
  apply in_full_destruct;auto.
Qed.
