coq-club - Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Cc: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>, "Gaetan Gilbert" <gaetan.gilbert AT ens-lyon.fr>
  • Subject: Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • Date: Sun, 5 Mar 2017 14:43:23 +0000
  • Accept-language: en-US, sv-SE
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lars.rasmusson AT ri.se; spf=Pass smtp.mailfrom=lars.rasmusson AT ri.se; spf=None smtp.helo=postmaster AT se-out1.mx-wecloud.net
  • Ironport-phdr: 9a23:RBO1fBM1mEjP/debVF8l6mtUPXoX/o7sNwtQ0KIMzox0KP38rarrMEGX3/hxlliBBdydsKMZzbGG+P6+ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9Msfogs+2z+G//YHIK0UN3WLlIOA6EBLj5w7Wr4wdhZZoAqc30BrA5HVSMawCzmRxYFmXghzU58Gq/Zcl/T4G6Nw78MsVdazgZOwCRKddES89NGZ9sMnirwKFVwKU42YHSWIQugBJRRPIukKpFqztuzf347IukBKROtf7GPVtAWyv
Many thanks to both of you! It is really helpful!
Cheers,
/Lars
> On 5 Mar 2017, at 14:56 , Dominique Larchey-Wendling
> wrote:
> Indeed the advice of Gaetan is very good. Another way
> to say it:
> When you need to show inversion lemmas for inductively defined
> predicates, consider *inverting the rules at once* and then
> instantiate on the particular form you need. Doing so, you end
> up using a simple destruct (pattern matching) which succeed
> when all parameters are variables. It usually fails when
> parameters and compound terms (like x::xs).
> I send you a variant of what Gaetan did with dependent
> inversion lemmas.
> Dominique
> ----- Mail original -----
>> De: "Gaetan Gilbert"
>> À:
>> Envoyé: Dimanche 5 Mars 2017 11:59:10
>> Objet: Re: [Coq-Club] Proving without decidable equality or excluded
>> middle.
>> I expected something like
>>> Definition IN_IND : same as your type.
>>> intros;dependent inversion pr.
>> to do it but apparently it can't.
>> I put one way to do it in the attached file. The intuition is that if we
>> want to prove something from the structure of (pr : IN foo bar) it's
>> easier if bar is a variable, so make an auxiliary lemma where it is a
>> variable and which proves the same thing on the value we're interested in.
>> Gaëtan Gilbert
>> On 04/03/2017 23:08, Lars Rasmusson wrote:
>>> The Agda proof [1] by G. Allais of the Pigeonhole does not use
>>> decidability
>>> or excluded
>>> middle. It defines a membership predicate and an induction lemma.
>>> data _∈_ {X : Set} (x : X) : (xs : List X) → Set where
>>> here! : {xs : List X} → x ∈ x ∷ xs
>>> there : {xs : List X} {y : X} (pr : x ∈ xs) → x ∈ y ∷ xs
>>> x∈y∷ys : {X : Set} {x y : X} {ys : List X} {P : (x : X) (pr : x ∈ y ∷ ys)
>>> Set}
>>> (phere! : P y here!) (pthere : (x : X) (pr : x ∈ ys) → P x (there
>>> pr))
>>> (pr : x ∈ y ∷ ys) → P x pr
>>> x∈y∷ys phere! pthere here! = phere!
>>> x∈y∷ys phere! pthere (there pr) = pthere _ pr
>>> On the last two lines, the proof of the induction lemma considers the two
>>> cases
>>> where pr was constructed using either the 'here!' constructor or the
>>> 'there' constructor.
>>> How would one do that in Coq? Inversion doesn't help here [2]...
>>> Variable (X : Type).
>>> Implicit Type (x : X).
>>> Inductive IN x : list X -> Prop :=
>>> | here xs : IN x (x :: xs)
>>> | there xs y : IN x xs -> IN x (y :: xs).
>>> Arguments here {_ _}.
>>> Arguments there {_ _ _}.
>>> Lemma IN_fwd: forall {x y xs}, IN x (y::xs) -> (x=y \/ IN x xs).
>>> now inversion 1; tauto.
>>> Qed.
>>> Definition IN_IND:
>>> forall {x y ys}
>>> {P : forall x, IN x (y::ys) -> Prop}
>>> (Phere : P y here)
>>> (Pthere : forall x (pr: IN x ys), P x (there pr))
>>> (pr : IN x (y::ys)), P x pr.
>>> Proof.
>>> intros.
>>> destruct (IN_fwd pr).
>>> subst.
>>> (* in the x=y case we have
>>> Phere : P y here
>>> pr : IN y (y :: ys)
>>> P y pr
>>> inversion pr.
>>> (* still no information that pr was created by 'here!' or 'there' *)
>>> How would one write the Agda proof in Coq? How can one compare proof
>>> objects (functions) based on which constructor they were built from
>>> (without
>>> EM,functional extensionality, JM_eq or other additional axioms)?
>>> Thanks!
>>> /Lars
>>> [1]
>>> https://github.com/gallais/potpourri/blob/master/agda/poc/PigeonHole.agda
>>> [2] https://x80.org/collacoq/agikoxayom.coq
> <php_from_agda.v>
