coq-club - Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving without decidable equality or excluded middle.
  • Date: Sun, 5 Mar 2017 14:56:23 +0100 (CET)
Indeed the advice of Gaetan is very good. Another way
to say it:
When you need to show inversion lemmas for inductively defined
predicates, consider *inverting the rules at once* and then
instantiate on the particular form you need. Doing so, you end
up using a simple destruct (pattern matching) which succeed
when all parameters are variables. It usually fails when
parameters and compound terms (like x::xs).
I send you a variant of what Gaetan did with dependent
inversion lemmas.
Dominique
----- Mail original -----
> De: "Gaetan Gilbert"
> <gaetan.gilbert AT ens-lyon.fr>
> À:
> Envoyé: Dimanche 5 Mars 2017 11:59:10
> Objet: Re: [Coq-Club] Proving without decidable equality or excluded middle.
> I expected something like
> >Definition IN_IND : same as your type.
> >intros;dependent inversion pr.
> to do it but apparently it can't.
> I put one way to do it in the attached file. The intuition is that if we
> want to prove something from the structure of (pr : IN foo bar) it's
> easier if bar is a variable, so make an auxiliary lemma where it is a
> variable and which proves the same thing on the value we're interested in.
> Gaëtan Gilbert
> On 04/03/2017 23:08, Lars Rasmusson wrote:
> > The Agda proof [1] by G. Allais of the Pigeonhole does not use
> > decidability
> > or excluded
> > middle. It defines a membership predicate and an induction lemma.
> > data _∈_ {X : Set} (x : X) : (xs : List X) → Set where
> > here! : {xs : List X} → x ∈ x ∷ xs
> > there : {xs : List X} {y : X} (pr : x ∈ xs) → x ∈ y ∷ xs
> > x∈y∷ys : {X : Set} {x y : X} {ys : List X} {P : (x : X) (pr : x ∈ y ∷ ys)
> > Set}
> > (phere! : P y here!) (pthere : (x : X) (pr : x ∈ ys) → P x
> > (there
> > pr))
> > (pr : x ∈ y ∷ ys) → P x pr
> > x∈y∷ys phere! pthere here! = phere!
> > x∈y∷ys phere! pthere (there pr) = pthere _ pr
> > On the last two lines, the proof of the induction lemma considers the two
> > cases
> > where pr was constructed using either the 'here!' constructor or the
> > 'there' constructor.
> > How would one do that in Coq? Inversion doesn't help here [2]...
> > Variable (X : Type).
> > Implicit Type (x : X).
> > Inductive IN x : list X -> Prop :=
> > | here xs : IN x (x :: xs)
> > | there xs y : IN x xs -> IN x (y :: xs).
> > Arguments here {_ _}.
> > Arguments there {_ _ _}.
> > Lemma IN_fwd: forall {x y xs}, IN x (y::xs) -> (x=y \/ IN x xs).
> > now inversion 1; tauto.
> > Qed.
> > Definition IN_IND:
> > forall {x y ys}
> > {P : forall x, IN x (y::ys) -> Prop}
> > (Phere : P y here)
> > (Pthere : forall x (pr: IN x ys), P x (there pr))
> > (pr : IN x (y::ys)), P x pr.
> > Proof.
> > intros.
> > destruct (IN_fwd pr).
> > subst.
> > (* in the x=y case we have
> > Phere : P y here
> > pr : IN y (y :: ys)
> > P y pr
> > inversion pr.
> > (* still no information that pr was created by 'here!' or 'there' *)
> > How would one write the Agda proof in Coq? How can one compare proof
> > objects (functions) based on which constructor they were built from
> > (without
> > EM,functional extensionality, JM_eq or other additional axioms)?
> > Thanks!
> > /Lars
> > [1]
> > https://github.com/gallais/potpourri/blob/master/agda/poc/PigeonHole.agda
> > [2] https://x80.org/collacoq/agikoxayom.coq
Attachment: php_from_agda.v
Description: Binary data
