- From: Tom Hirschowitz <tom.hirschowitz AT univ-smb.fr>
- To: "Paul A. Steckler" <steck AT stecksoft.com>, coq-club <coq-club AT inria.fr>
- Cc:
- Subject: Re: [Coq-Club] Unicode tokens?
- Date: Tue, 07 Mar 2017 21:02:22 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tom.hirschowitz AT univ-smb.fr; spf=SoftFail smtp.mailfrom=tom.hirschowitz AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout01.partage.renater.fr
Aha, right, I've already encountered this one, but had forgotten.
Apparently, company-coq isn't much better: it displays something like
delta₁.
Good luck!
Tom
"Paul A. Steckler"
writes:
> On Tue, Mar 7, 2017 at 5:43 AM, Tom Hirschowitz
> wrote:
>> What kind of bugs are you thinking of?
> For example, in the PG file coq/example-tokens.v, there is the text
> "delta__1", which should show a subscripted Greek letter. Instead, the
> text appears verbatim.
> I think I've tracked down this bug to the regular expression that's
> generated for token matching.
> -- Paul
- [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Makarius, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Christian Doczkal, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Benjamin C. Pierce, 03/07/2017
- Message not available
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Pierre Courtieu, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Vadim Zaliva, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Matej Kosik, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Makarius, 03/08/2017
