- From: Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Unicode tokens?
- Date: Wed, 8 Mar 2017 19:23:24 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=Pass smtp.mailfrom=5764c029b688c1c0d24a2e97cd764f AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f53.google.com
- Ironport-phdr: 9a23:gHtFJBSww9V1u1K30PYCinpaydpsv+yvbD5Q0YIujvd0So/mwa67bRWN2/xhgRfzUJnB7Loc0qyN4v2mBTBLuM7R+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYZBwNjz6ga5tzKg+3pEPfrJo4m4xnf4M41hbL6lhPYOVVjTc1egzPlE6mt83urM5oqi8It6h9/pRNAPrxc/tmEbJwAzEvMmRz78ru40qQBTCT72cRBz1F2iFDBBLIuUn3
Hi Vadim,
On 03/08/2017 06:32 PM, Vadim Zaliva wrote:
> One problem with Unicode is working with files outside Emacs. For example,
> if my source files use greek letter delta as Unicode character it makes it
> difficult to use command-line tools like grep or
> "/" command in "more" in the lack of emacs Unicode input facilities.
I guess that it is not the responsibility of the "grep" and friends to enable
you to type unicode characters.
(it is the job of programs providing "input method", I guess, such as "xim",
"uim" and many others).
I guess that few people bother using Unicode glyphs because Emacs ships
broken fonts.
> This is the reason I prefer to save .v files as ASCII, but I really love
> Unicode rendering in emacs.
> CMU ECE PhD candidate
> Mobile: +1(510)220-1060
> On Wed, Mar 8, 2017 at 8:34 AM, Pierre Courtieu
> <pierre.courtieu AT gmail.com
> <mailto:pierre.courtieu AT gmail.com>>
> wrote:
> The bug is fixed in github now.
> The question remains to decide if we keep this feature in pg.
> The main advantage of this feature is that you keep non-unicode text
> in your files. Still today it seems to be an advantage. I don't
> understand exactly why because now all editors support unicode. But
> people still fear unicode.
> The main disadvantage of this feature is that it introduces
> inconsistencies between view modes of a file: the length of lines is
> not the same with or without the tokens hence the layout of your files
> is ugly in either one or the other mode.
> I tend to use unicode when I work alone, and stick to ascii/latin when
> working with others. In these cases I kind of like unicode tokens. But
> going for company-coq pretty-printing is straightforward.
> P.
> 2017-03-07 16:48 GMT+01:00 Paul A. Steckler
> <steck AT stecksoft.com
> <mailto:steck AT stecksoft.com>>:
> > On Tue, Mar 7, 2017 at 5:43 AM, Tom Hirschowitz
> <tom.hirschowitz AT univ-smb.fr
> <mailto:tom.hirschowitz AT univ-smb.fr>>
> wrote:
> >> What kind of bugs are you thinking of?
> > For example, in the PG file coq/example-tokens.v, there is the text
> > "delta__1", which should show a subscripted Greek letter. Instead, the
> > text appears verbatim.
> > I think I've tracked down this bug to the regular expression that's
> > generated for token matching.
> > -- Paul
- Re: [Coq-Club] Unicode tokens?, (continued)
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Benjamin C. Pierce, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Christian Doczkal, 03/07/2017
- Message not available
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Pierre Courtieu, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Vadim Zaliva, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Matej Kosik, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Makarius, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Matej Kosik, 03/09/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/09/2017
- Re: [Coq-Club] Unicode tokens?, Ralf Jung, 03/12/2017
