- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Cc: Tom Hirschowitz <tom.hirschowitz AT univ-smb.fr>
- Subject: Re: [Coq-Club] Unicode tokens?
- Date: Wed, 8 Mar 2017 17:34:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f54.google.com
- Ironport-phdr: 9a23:dEzMwRxlNMbOo/PXCy+O+j09IxM/srCxBDY+r6Qd0esUIJqq85mqBkHD//Il1AaPBtSGra4YwLqJ++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9Dq3PF4XTl8W60fyps92WOl0QxWn1XbQnBxKv5S7Vq8Ne1YBlM+M6zgbDinpOYeVfg21ycwG9hRH5s/+x8YR5/mx7vO87689NTO2uZ6U1V6ZVSj8hLnop5cD2nRbGRAqLoHAbVzNFwVJzHwHZ4USiDd/KuSzgu784gXHCMA==
The bug is fixed in github now.
The question remains to decide if we keep this feature in pg.
The main advantage of this feature is that you keep non-unicode text
in your files. Still today it seems to be an advantage. I don't
understand exactly why because now all editors support unicode. But
people still fear unicode.
The main disadvantage of this feature is that it introduces
inconsistencies between view modes of a file: the length of lines is
not the same with or without the tokens hence the layout of your files
is ugly in either one or the other mode.
I tend to use unicode when I work alone, and stick to ascii/latin when
working with others. In these cases I kind of like unicode tokens. But
going for company-coq pretty-printing is straightforward.
P.
2017-03-07 16:48 GMT+01:00 Paul A. Steckler
<steck AT stecksoft.com>:
> On Tue, Mar 7, 2017 at 5:43 AM, Tom Hirschowitz
> wrote:
>> What kind of bugs are you thinking of?
> For example, in the PG file coq/example-tokens.v, there is the text
> "delta__1", which should show a subscripted Greek letter. Instead, the
> text appears verbatim.
> I think I've tracked down this bug to the regular expression that's
> generated for token matching.
> -- Paul
- Re: [Coq-Club] Unicode tokens?, (continued)
- Re: [Coq-Club] Unicode tokens?, Christian Doczkal, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/06/2017
- Re: [Coq-Club] Unicode tokens?, Benjamin C. Pierce, 03/07/2017
- Message not available
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/07/2017
- Re: [Coq-Club] Unicode tokens?, Théo Zimmermann, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Tom Hirschowitz, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Pierre Courtieu, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Vadim Zaliva, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Matej Kosik, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Paul A. Steckler, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Makarius, 03/08/2017
- Re: [Coq-Club] Unicode tokens?, Matej Kosik, 03/09/2017
- Re: [Coq-Club] Unicode tokens?, Clément Pit-Claudel, 03/09/2017
