- To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7
- Date: Sat, 4 Nov 2017 13:10:58 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=None smtp.helo=postmaster AT NAM04-SN1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:EDyx0hPI7+/aS32Z2Rkl6mtUPXoX/o7sNwtQ0KIMzox0K/X8rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6aijSI4DUTAhTyMxZubqSwQ9aKzpf/6+fn24DcZE1oiSC3bLdzKl3ijRjesY82jJFoJ6IwzDPIpGFJcqJY3zU7C0iUmkPf68G28YJjux5Xtrp19MNGXb/9cow4SqBdBTUidWsy4Zu45lH4UQKT6y5EAS0tmR1SDl2AtUmiUw==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Didn't work.
Does someone have a sample project that uses "VERNAC COMMAND EXTEND" (and also "TACTIC EXTEND" or what ever it became) for Coq 8.7?
- Ken
Sent: Saturday, November 4, 2017 1:04 AM
To: Kenneth Roe
Cc: Coq-Club
To: Kenneth Roe
Cc: Coq-Club
Hi, try adding an "open Stdarg". Best. Hugo
On Sat, Nov 04, 2017 at 03:57:20AM +0000, Kenneth Roe wrote:
> I am in the process of converting an ML plugin to Coq 8.7. I have the
> following construct to declare some commands (inside a .ml4 file):
> VERNAC COMMAND EXTEND AR
> | [ "printAST" constr(def) ] -> [ Stuff.print_ast 0 def ]
> | [ "printExp" constr(def) ] -> [ Stuff.print_exp 0 def ]
> | [ "printAST" constr(def) "with" "depth" integer(depth)] -> [ Stuff.print_ast
> depth def ]
> END
> When I compile, I get the following error:
> File "src/plugin.ml4", line 1511, characters 2-57:
> Error: Unbound value wit_constr
> How do I correct this error?
> - Ken
> depth def ]
> END
> - Ken
- [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Hugo Herbelin, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Matej Košík, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Maxime Dénès, 11/04/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Kenneth Roe, 11/05/2017
- Re: [Coq-Club] Converting VERNAC COMMAND declaration to Coq 8.7, Matej Košík, 11/05/2017
